1 - 4 of 4 Posts
Has anyone replaced their door woofers and measured the mounting depth inside the door? I'm looking at various 10" midbasses.. the bose 10" woofer has a good inch of thickness facing out, so I know I can put a fairly thick spacer on there. Thanks!
I did the right door from the top of the plastic adapter/spacer where the woofer mounts, to the structural beam that gets in the way of the woofer, and it measured between 2.125" & 2.25" (depending on how the woofer lines up against this beam). This top portion of the Bose woofer you mentioned facing out is 7/8". Adding a 1 inch spacer on top of the existing adapter nets you 3.125" clearance to the beam structure. The Bose woofer itself has at the very least another .5" clearance from its top edge to the interior door panel that goes over it. So adding 1.5" spacer on top of the plastic adapter easily gets you 3.5" with 0.125 inch clearance to the beam.
1 - 4 of 4 Posts
