I feel like one of the videos I watched mentioned that the ability to select your steering ratio was going to be an option, not standard. Perhaps the vague language of the order sheet is referring to that.They mention steer by wire as a feature. Does that mean if you don't get the deluxe touring you will not have steer by wire?
I'm thinking since this is an internal data sheet, it probably isn't telling you what the standard equipment is for each model. I would suspect above the base model that the moonroof is standard. Same goes with Nav. I can't imagine it is not an option on the hybrid.Great find.
Why is the moon roof only available on the base model and leather seats only available on the Premium model? Am I reading this right?
The hybrid will be in RWD too? interesting... This is the beginning of fun and performance with hybrids not going to be your average Prius. I like the way this is goingLooks like the hybrid will be available in both RWD and AWD.
When they put REQ under the Q50 packages are they referring to REQUIRED?
So they moonroof is required on the base Q50? o.0
That sounds right to me. Also, the X marks mean that the particular option is available on the chosen model.I think that the REQ (Required) is for the 50 State Emissions on the first line.
Not sure about this look with the painted mudguards. I find that it would most likely throw off the body shape and lines. I wouldn't suggest this to infiniti but really anything goes with acquired taste, just cant see majority liking this.I'd like to see how the body color splash guards will look, most i've seen look ugly like on the solstice below. i doubt it will be a common Q50 accessory people get;
Ahhh.. So moonroof is available for all models except the base - where it is an option.That sounds right to me. Also, the X marks mean that the particular option is available on the chosen model.
Pretty awesome sunroof is available on all models except base. It makes the higher up models cooler and the base model cheaper so it helps even more at aiming to people looking for a super affordable entry level luxury sedan.Ahhh.. So moonroof is available for all models except the base - where it is an option.
They had to exclude the base model of something.It will help drive more people to buy the higher models but just how much of a demand is there really for moon roofs. Does it make that much of a difference though? I remember it use to be a big thing back then as it was a huge luxury. I mean Im not complaining but if you ask me at this day and age they should included that as a standard now now like power windows.
As far as pricing goes, one thing I can tell you is that the Q50 Hybrid models can easily go for the low to high $40k's, even higher up into the low to mid $50k's.Hmmm I should probably print this out and compare it to the other cars I am looking at. Too bad there is no prices yet. That would make my decision so much easier. There are so many options! If I can save gas with the hybrid and it doesn't cost too much I might consider it.
I am kind of leaning towards jumping over to Lexus. I think the new IS350 is such a pretty looking car.
