1 - 11 of 11 Posts
Hello all. I'm new to the forum and I recently picked up a 2015 CPO Q50S to replace my G37X in march. The car only had 9835 miles when I bought it. So far the experience has been terrible. Within a week of owning the car it had to go back to to the dealership because it had bad brakes, failed catalytic converters, and bunch of maintenance lights going off. The worst issue is a strange rattle from the engine compartment. The car is at the dealership as we speak for the third time concerning this issue. The Infiniti dealership that I bought it from can't seem to figure whats wrong with it. It's hard to describe the sound but imagine having a metallic like rattle in the engine bay. I also tried to attach a link to a video of it. Not sure if I did it right tho. Anyone experience this?
Q50 Rattle Noise
Moderator
Sounds like something's loose underneath the car. Have you been underneath to check for a loose exhaust component or heat shield?
I looked underneath and everything was good. The dealership did the same thing. Original they thought it was the lower engine cover so they replaced it and the issue still remains. At this point they stated they are going to take the front end apart and look deeper to see whats causing it. This is last attempt at fixing it before looking into other options. Since buying the car in march it's spent about 60% of it time at the dealership. I've been driving loaners more than my actual car.
Hmmm. That is a weird sound. Sounds are a nightmare to try and actually tell where they're coming from in a video though. To me it definitely sounds like some sort of plastic piece loose in the engine compartment. My thoughts would be cooling fan heat shroud being loose, its a 2 piece shield, or the cooling fans themselves being bad and the blades are coming in contact with the shroud.
Discussion Starter #5
For some reason the dealership can't figure out where its coming from. It's so weird.
2016 Q50 Red Sport AWD. Fully loaded. Stock (for now..)
Sounds like it's only doing it at idle in neutral. Does it do it in gear while holding the brake at a stand still?
Discussion Starter #7
Yes it does. It also does it when i'm driving. I'll be driving down the street and it will randomly start making that sound for 15 to 30 seconds and then it'll stop. I hear that sound atleast twice a day regardless of whether I'm idling or moving.
Is it the AC compressor? Have they checked that? Maybe the torque converter?
Discussion Starter #9
It's been at the dealership since Thursday. They stated they are going to take the front end apart and try to diagnose and fix it. It just sucks because despite the issues I enjoy driving the car and I spend more time in loaners than my actual car. Right now I'm driving a 2019 QX60 which I absolutely hate.
I feel your pain man. I bought my 2016 on April 15th and it was back in the shop 3 days later for the accessory belt issue. Took them 2 and a half weeks to fix it. They gave me a QX50 as a loaner. I didn't drive it much since I'm teleworking due to COVID-19 and I have another vehicle to drive. Look at the positive side. It will cost you absolutely nothing to repair whatever the issue is. Lol
Discussion Starter #11
Lol. Very true. I'm so happy its under warranty.
1 - 11 of 11 Posts
