1 - 6 of 6 Posts
when using my Iphone mounted on the dashboard for directions, does it matter which USB port is used?
And, when driving, is there a way to have the spoken directions coming from an Iphone app such as "Waze" or "Google Maps", to be heard over the Infiniti sound system?
Just use Bluetooth and pair it with the care and you will be all set.
so you're saying simply go into the Iphone settings and pair it to the Q50 Bluetooth as you would for hands-free voice calls and the sound directions from WAZE or "MAPS" will come through the car speakers?
remember, I do not have standard navigation, just the Iphone mounted on the dash.
You are correct. Pair it and you will be good to go.
2016 Hybrid 3.5 SportTech RWD
IIrc you also have to activate the A2DP protocol after pairing the telephone...
Edit
Found it in the InTouch manual: When the pairing is completed, the screen will change to the Bluetooth®setup display. If the registered device has both audio and phone function, the system displays a message asking if you would like to register the device for another function.
Also if you’re using any source other than BT and navigation app you have to play navigation audio as Bluetooth phone call under google maps or waze settings.
1 - 6 of 6 Posts
