1 - 7 of 7 Posts
I purchased a 2019 Sport last week, noticed small pieces of plastic sheeting hanging from the bottom of all of the door panels. After doing some research determined that this is for moisture and dust control. Has anyone else experienced this?
Nope. Is the sheets blue or clear? If blue it could be just leftover from the PDI process but if clear, maybe somebody was doing some work on the door and didnt properly align the plastic sheet back up. Not a biggie imo
Please supply pictures. Likely is just remnants of the shipping plastic that is installed on the vehicle. The pre delivery process should've removed all of it, but in reality someone moving fast and half-a$$ing it is going to leave remnants. I had to pull a few small pieces off after delivery.
Reactions: Avedis53
Thank you.
Automotive tire Hood Automotive lighting Synthetic rubber Road surface
Yep that is just the shipping plastic. You can just tear that off or get a razor to carefully cut it back and off so none is showing.
Reactions: xBlitzkriegx
1 - 7 of 7 Posts
