Located in
(6) Xenon Blue 3-SMD 6641 LED Bulbs For Car Sun Visor Vanity Mirror Lights
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
(6) Xenon Blue 3-SMD 6641 LED Bulbs For Car Sun Visor Vanity Mirror Lights Description This auction features 3 pairs*Blue*3-SMD D29mm LED Bulbs for vanity mirror lights The 3-SMD Fuse shape D29mm LED bulb will replace the stock 6614F and TS-14V1CP bulb and will fit the Acura, Honda, Infiniti, Nissan, Toyota, Subaru, Mazda, Mitsubishi, etc in the parts compatibility list. Features: * *Size: 1.15" (29mm) long * *Super*Blue* * *3 pieces super bright 3-Emitter 5050 SMD on each bulb * *Voltage: 12V * *Lifespan: 30000 working hours * *Low current consumption * *Fits part numbers 6614, 6614F, F30-WHP*and TS-14V1CP bulbs * *This LED bulb is polar sensitive, so in case the bulb won't light up, please flip it 180 degrees Fitment IMPORTANT Fitment information provided is for reference only. Please make sure to match the exact part numbers between this part and the part that you are replacing. Contact your mechanics, or send us a message to make sure it matches exactly in case of doubt before purchasing. Seller is not responsible if you are buying non-matching parts. # Notes Year Make Model Trim / Engine 1 2014 Acura ILX Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS SOHC Naturally Aspirated Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated Hybrid Sedan 4-Door / 1.5L 1497CC l4 ELECTRIC/GAS SOHC Naturally Aspirated 2 2014 Acura RDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 3 2014 Acura RLX Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 4 2014 Cadillac ATS Base / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Base / 2.5L 2457CC 150Cu. In. l4 GAS N/R Naturally Aspirated Luxury / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Luxury / 2.5L 2457CC 150Cu. In. l4 GAS N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Performance / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Performance / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Premium / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Premium / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated 5 2014 Cadillac CTS Base / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Base / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Vsport / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled 6 2014 Cadillac SRX Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Luxury Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Performance Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Premium Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 7 2014 Cadillac XTS Base / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled Platinum / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Platinum / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled Premium / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Premium / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled 8 2014 Chevrolet Equinox LS / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LT / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LT / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated LTZ / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LTZ / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated 9 2014 Chevrolet Impala Eco Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated LS Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LT Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LT Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated LTZ Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LTZ Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 10 2014 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 11 2014 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SE Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated SE Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SXT Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 12 2014 Dodge Durango Citadel Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated Citadel Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated Limited Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated Limited Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated Rallye Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SXT Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 13 2014 Ford C-Max Energi / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated Hybrid SE / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated Hybrid SEL / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated 14 2014 Ford Escape S Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated SE Sport Utility 4-Door / 1.6L 1601CC 98Cu. In. l4 GAS DOHC Turbocharged SE Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Titanium Sport Utility 4-Door / 1.6L 1601CC 98Cu. In. l4 GAS DOHC Turbocharged Titanium Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged 15 2014 Ford Explorer Base Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Base Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Limited Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Sport Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 16 2014 Ford Flex Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated SEL Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated SEL Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 17 2014 Ford Fusion Energi SE Luxury Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated Energi Titanium Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated S Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated S Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated SE Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated SE Sedan 4-Door / 1.6L 1596CC 97Cu. In. l4 GAS DOHC Turbocharged SE Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged SE Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Titanium Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated Titanium Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged 18 2014 GMC Acadia Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated SLE Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 19 2014 GMC Sierra 1500 Base Crew Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated Base Extended Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated Base Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Crew Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Extended Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Crew Cab Pickup 4-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated SLT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Extended Cab Pickup 4-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated SLT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Standard Cab Pickup 2-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated 20 2014 GMC Terrain Denali Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated SLE Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated SLT Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 21 2014 Honda Accord Plug-In Sedan 4-Door / 2.0L 1993CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 22 2014 Infiniti Q50 Base / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Hybrid Premium / 3.5L 3498CC V6 ELECTRIC/GAS N/R Naturally Aspirated Hybrid Sport / 3.5L 3498CC V6 ELECTRIC/GAS N/R Naturally Aspirated Premium / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Sport / 3.7L 3696CC V6 GAS N/R Naturally Aspirated 23 2014 Infiniti QX80 Base / 5.6L 5552CC V8 GAS N/R Naturally Aspirated 24 2014 Mazda 6 Grand Touring Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Touring Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 25 2014 Mazda CX-5 Grand Touring Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Sport Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated Touring Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 26 2014 Nissan 370Z Base / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Nismo / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Touring / 3.7L 3696CC V6 GAS N/R Naturally Aspirated 27 2014 Nissan GT-R Black Edition Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged Track Edition Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 28 2014 Nissan Murano CrossCabriolet Convertible 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 29 2013 Acura ILX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 30 2013 Acura RDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 31 2013 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 32 2013 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 33 2013 Buick LaCrosse Base Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 34 2013 Cadillac ATS Base Sedan 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged 35 2013 Chevrolet Impala LS Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 36 2013 Chevrolet Malibu LS Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated 37 2013 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 38 2013 Chrysler 200 LX Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 39 2013 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 40 2013 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 41 2013 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 42 2013 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 43 2013 Dodge Dart SE Sedan 4-Door / 2.0L 1995CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 44 2013 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 45 2013 Dodge Journey SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 46 2013 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 47 2013 Ford Escape S Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 48 2013 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX N/R Naturally Aspirated 49 2013 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 50 2013 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 51 2013 Ford Mustang Base Coupe 2-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 52 2013 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 53 2013 GMC Terrain Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 54 2013 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 55 2013 Infiniti EX37 Base Sport Utility 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 56 2013 Infiniti FX37 Base Sport Utility 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 57 2013 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 58 2013 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 59 2013 Infiniti JX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 60 2013 Infiniti M35h Base Sedan 4-Door / 3.5L 3498CC V6 ELECTRIC/GAS DOHC Naturally Aspirated 61 2013 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 62 2013 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 63 2013 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 64 2013 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 65 2013 Mazda CX-5 Sport Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 66 2013 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 67 2013 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 68 2013 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 69 2013 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 70 2013 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 71 2013 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 72 2013 Subaru BRZ Limited Coupe 2-Door / 2.0L 1998CC 122Cu. In. H4 GAS DOHC Naturally Aspirated Premium Coupe 2-Door / 2.0L 1998CC 122Cu. In. H4 GAS DOHC Naturally Aspirated 73 2013 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 74 2013 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2498CC 152Cu. In. H4 GAS DOHC Naturally Aspirated 75 2013 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2498CC 152Cu. In. H4 GAS DOHC Naturally Aspirated 76 2013 Toyota Land Cruiser Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 77 2013 Toyota Sienna Base Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 78 2013 Volvo XC90 3.2 Sport Utility 4-Door / 3.2L 3192CC l6 GAS DOHC Naturally Aspirated 79 2012 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 80 2012 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 81 2012 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 82 2012 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 83 2012 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 84 2012 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 85 2012 Buick Enclave Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 86 2012 Buick LaCrosse Base Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 87 2012 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 88 2012 Cadillac SRX Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 89 2012 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 90 2012 Chevrolet Cruze LS Sedan 4-Door / 1.8L 1796CC 110Cu. In. l4 GAS DOHC Naturally Aspirated 91 2012 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated 92 2012 Chevrolet Impala LS Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 93 2012 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 94 2012 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 95 2012 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 96 2012 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 97 2012 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 98 2012 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 99 2012 Chrysler 200 LX Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 100 2012 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 101 2012 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 102 2012 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 103 2012 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 104 2012 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 105 2012 Dodge Journey SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 106 2012 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 107 2012 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 108 2012 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 109 2012 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 110 2012 Ford F-150 XL Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 111 2012 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 112 2012 Ford Focus S Sedan 4-Door / 2.0L 121Cu. In. l4 GAS DOHC Naturally Aspirated 113 2012 Ford Mustang Base Coupe 2-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 114 2012 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 115 2012 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 116 2012 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 117 2012 GMC Terrain SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated 118 2012 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 119 2012 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 120 2012 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 121 2012 Honda CR-Z Base Hatchback 2-Door / 1.5L 1497CC 91Cu. In. l4 ELECTRIC/GAS SOHC Naturally Aspirated 122 2012 Honda Crosstour EX Hatchback 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 123 2012 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 124 2012 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 125 2012 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 126 2012 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 127 2012 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 128 2012 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 129 2012 Infiniti G25 Base Sedan 4-Door / 2.5L 2496CC 152Cu. In. V6 GAS DOHC Naturally Aspirated 130 2012 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 131 2012 Infiniti M35h Base Sedan 4-Door / 3.5L 3498CC V6 ELECTRIC/GAS DOHC Naturally Aspirated 132 2012 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 133 2012 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 134 2012 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 135 2012 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 136 2012 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 137 2012 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 138 2012 Lexus IS250 C Convertible 2-Door / 2.5L 2499CC V6 GAS DOHC Naturally Aspirated 139 2012 Lexus IS350 C Convertible 2-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 140 2012 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 141 2012 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 142 2012 Lincoln MKX Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 143 2012 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 144 2012 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 145 2012 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 146 2012 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 147 2012 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 148 2012 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 149 2012 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 150 2012 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 151 2012 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 152 2012 Mitsubishi Outlander Sport ES Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 153 2012 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 154 2012 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 155 2012 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 156 2012 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 157 2012 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 158 2012 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 159 2012 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 160 2012 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 161 2012 Nissan Titan SL Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 162 2012 Ram 1500 Tradesman Crew Cab Pickup 4-Door / 4.7L 285Cu. In. V8 FLEX SOHC Naturally Aspirated 163 2012 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 164 2012 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 165 2012 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 166 2012 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 FLEX DOHC Naturally Aspirated 167 2012 Toyota Sienna Base Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 168 2012 Volvo C30 T5 Hatchback 2-Door / 2.5L 2521CC l5 GAS DOHC Turbocharged 169 2012 Volvo S60 T5 Sedan 4-Door / 2.5L 2521CC l5 GAS DOHC Turbocharged 170 2012 Volvo XC90 3.2 Sport Utility 4-Door / 3.2L 3192CC l6 GAS DOHC Naturally Aspirated 171 2011 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 172 2011 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 173 2011 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 174 2011 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 175 2011 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 176 2011 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 177 2011 Buick Enclave CX Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 178 2011 Buick LaCrosse CXL Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 179 2011 Cadillac CTS Base Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 180 2011 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 181 2011 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 182 2011 Cadillac SRX Base Sport Utility 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 183 2011 Cadillac STS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 184 2011 Chevrolet Avalanche LS Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 185 2011 Chevrolet Cruze LS Sedan 4-Door / 1.8L 1796CC 110Cu. In. l4 GAS DOHC Naturally Aspirated 186 2011 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated 187 2011 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 188 2011 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 189 2011 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 190 2011 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 191 2011 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 192 2011 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 193 2011 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 194 2011 Chrysler 200 LX Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 195 2011 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 196 2011 Dodge Avenger Express Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 197 2011 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 198 2011 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 199 2011 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 200 2011 Dodge Nitro Heat Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 201 2011 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 202 2011 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 203 2011 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 204 2011 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 205 2011 Ford F-150 XL Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 206 2011 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 207 2011 Ford Focus S Sedan 4-Door / 2.0L 121Cu. In. l4 GAS DOHC Naturally Aspirated 208 2011 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 209 2011 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 210 2011 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 211 2011 GMC Terrain SLE Sport Utility 4-Door / 3.0L 182Cu. In. V6 FLEX DOHC Naturally Aspirated 212 2011 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 213 2011 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 214 2011 Honda Accord Crosstour EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 215 2011 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 216 2011 Honda CR-Z Base Hatchback 2-Door / 1.5L 1497CC 91Cu. In. l4 ELECTRIC/GAS SOHC Naturally Aspirated 217 2011 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 218 2011 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 219 2011 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 220 2011 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 221 2011 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 222 2011 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 223 2011 Infiniti G25 Base Sedan 4-Door / 2.5L 2496CC 152Cu. In. V6 GAS DOHC Naturally Aspirated 224 2011 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 225 2011 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 226 2011 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 227 2011 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 228 2011 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 229 2011 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 230 2011 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 231 2011 Lexus IS250 C Convertible 2-Door / 2.5L 2499CC V6 GAS DOHC Naturally Aspirated 232 2011 Lexus IS350 C Convertible 2-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 233 2011 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 234 2011 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 235 2011 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 236 2011 Lincoln MKX Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 237 2011 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 238 2011 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 239 2011 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 240 2011 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 241 2011 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 242 2011 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 243 2011 Mazda RX-8 Sport Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 244 2011 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 245 2011 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 246 2011 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 247 2011 Mitsubishi Outlander Sport ES Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 248 2011 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 249 2011 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 250 2011 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 251 2011 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 252 2011 Nissan Murano SV Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 253 2011 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 254 2011 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 255 2011 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 256 2011 Nissan Titan SL Crew Cab Pickup 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 257 2011 Ram 1500 Laramie Extended Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 258 2011 Ram Dakota ST Extended Cab Pickup 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 259 2011 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 260 2011 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 261 2011 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 262 2011 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 FLEX DOHC Naturally Aspirated 263 2011 Toyota Sienna Limited Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 264 2010 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 265 2010 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 266 2010 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 267 2010 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 268 2010 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 269 2010 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 270 2010 Buick Enclave CX Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 271 2010 Buick LaCrosse CXL Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 272 2010 Cadillac CTS Base Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 273 2010 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 274 2010 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 275 2010 Cadillac SRX Base Sport Utility 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 276 2010 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 277 2010 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 278 2010 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 279 2010 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 280 2010 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 281 2010 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 282 2010 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 283 2010 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 284 2010 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 285 2010 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 286 2010 Dodge Avenger R/T Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 287 2010 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 288 2010 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 289 2010 Dodge Nitro SE Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 290 2010 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 291 2010 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 292 2010 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 293 2010 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 294 2010 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 295 2010 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 296 2010 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 297 2010 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 298 2010 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 299 2010 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 300 2010 GMC Terrain SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 301 2010 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 302 2010 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 303 2010 Honda Accord Crosstour EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 304 2010 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 305 2010 Honda Odyssey EX-L Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 306 2010 Honda Pilot LX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 307 2010 Honda Ridgeline RTS Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 308 2010 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 309 2010 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 310 2010 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 311 2010 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 312 2010 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 313 2010 Jeep Commander Sport Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 314 2010 Jeep Compass Limited Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 315 2010 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 316 2010 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 317 2010 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 318 2010 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 319 2010 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 320 2010 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 321 2010 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 322 2010 Lincoln MKX Base Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 323 2010 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 324 2010 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 325 2010 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 326 2010 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 327 2010 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 328 2010 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 329 2010 Mazda RX-8 Grand Touring Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 330 2010 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 331 2010 Mitsubishi Endeavor LS Sport Utility 4-Door / 3.8L 3828CC 230Cu. In. V6 GAS SOHC Naturally Aspirated 332 2010 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 333 2010 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 334 2010 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 335 2010 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 336 2010 Nissan Armada SE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 337 2010 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 338 2010 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 339 2010 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 340 2010 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 341 2010 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 342 2010 Nissan Titan PRO-4X Extended Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 343 2010 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 344 2010 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 345 2010 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 346 2010 Toyota Sienna XLE Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 347 2010 Toyota Tundra SR5 Crew Cab Pickup 4-Door / 4.6L 4608CC V8 GAS DOHC Naturally Aspirated 348 2009 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 349 2009 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 350 2009 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 351 2009 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 352 2009 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 353 2009 Cadillac CTS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 354 2009 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 355 2009 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 356 2009 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 357 2009 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 358 2009 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 359 2009 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 360 2009 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 361 2009 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 362 2009 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 363 2009 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 364 2009 Chevrolet Tahoe LS Sport Utility 4-Door / 4.8L 294Cu. In. V8 GAS OHV Naturally Aspirated 365 2009 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 366 2009 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 367 2009 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 368 2009 Dodge Avenger R/T Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 369 2009 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 370 2009 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 371 2009 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 372 2009 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 373 2009 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 374 2009 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 375 2009 Ford Escape XLT Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 376 2009 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 377 2009 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 378 2009 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 379 2009 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 380 2009 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 381 2009 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 382 2009 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 383 2009 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 384 2009 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 385 2009 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 386 2009 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 387 2009 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 388 2009 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 389 2009 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 390 2009 Infiniti EX35 Journey Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 391 2009 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 392 2009 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 393 2009 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 394 2009 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 395 2009 Jeep Commander Sport Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 396 2009 Jeep Compass Limited Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 397 2009 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.0L 2985CC 182Cu. In. V6 DIESEL DOHC Turbocharged 398 2009 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 399 2009 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 400 2009 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 401 2009 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 402 2009 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 403 2009 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 404 2009 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 405 2009 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 406 2009 Mazda RX-8 R3 Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 407 2009 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 408 2009 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 409 2009 Mitsubishi Outlander XLS Sport Utility 4-Door / 3.0L 2998CC 182Cu. In. V6 GAS SOHC Naturally Aspirated 410 2009 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 411 2009 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 412 2009 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 413 2009 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 414 2009 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 415 2009 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 416 2009 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated SL Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 417 2009 Nissan Rogue SL Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 418 2009 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 419 2009 Nissan Titan PRO-4X Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 420 2009 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 421 2009 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 422 2009 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 423 2009 Toyota Sienna CE Mini Cargo Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 424 2009 Toyota Tundra SR5 Crew Cab Pickup 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 425 2008 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 426 2008 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 427 2008 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 428 2008 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 429 2008 Cadillac CTS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 430 2008 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 431 2008 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 432 2008 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 433 2008 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 434 2008 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 435 2008 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 436 2008 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 437 2008 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 438 2008 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 439 2008 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 440 2008 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 441 2008 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 442 2008 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 443 2008 Dodge Avenger R/T Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 444 2008 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 445 2008 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 446 2008 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 447 2008 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 448 2008 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 449 2008 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 450 2008 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 451 2008 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 452 2008 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 453 2008 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 454 2008 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 455 2008 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 456 2008 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 457 2008 GMC Yukon Denali Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 458 2008 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 459 2008 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 460 2008 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 461 2008 Honda Pilot Value Package Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 462 2008 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 463 2008 Infiniti EX35 Journey Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 464 2008 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 465 2008 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 466 2008 Infiniti G35 Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 467 2008 Infiniti G37 Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 468 2008 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 469 2008 Jeep Commander Sport Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 470 2008 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 471 2008 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 472 2008 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 473 2008 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 474 2008 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 475 2008 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 476 2008 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 477 2008 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 478 2008 Mazda RX-8 40th Anniversary Edition Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 479 2008 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 480 2008 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 481 2008 Mitsubishi Outlander SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 482 2008 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 483 2008 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 484 2008 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 485 2008 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 486 2008 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 487 2008 Nissan Titan LE Extended Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 488 2008 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 489 2008 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 490 2008 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 491 2008 Toyota Sienna Limited Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 492 2008 Toyota Tundra Base Standard Cab Pickup 2-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 493 2007 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 494 2007 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 495 2007 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 496 2007 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 497 2007 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 498 2007 Cadillac DTS L Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 499 2007 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 500 2007 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 501 2007 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 502 2007 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 503 2007 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 504 2007 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 505 2007 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 GAS OHV Naturally Aspirated 506 2007 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 507 2007 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 508 2007 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 509 2007 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 510 2007 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 511 2007 Dodge Charger SE Sedan 4-Door / 2.7L 2700CC 167Cu. In. V6 GAS DOHC Naturally Aspirated 512 2007 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 513 2007 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 514 2007 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 515 2007 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 516 2007 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 517 2007 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 518 2007 Ford F-150 XL Standard Cab Pickup 2-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 519 2007 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 520 2007 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 521 2007 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 522 2007 GMC Yukon Denali Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 523 2007 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated 524 2007 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 525 2007 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 526 2007 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 527 2007 Honda Ridgeline RTS Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 528 2007 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 529 2007 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 530 2007 Infiniti G35 Base Coupe 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 531 2007 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 532 2007 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 533 2007 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 534 2007 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 535 2007 Lincoln Navigator L Ultimate Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 536 2007 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 537 2007 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 538 2007 Mazda CX-9 Sport Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 539 2007 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 540 2007 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 541 2007 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 542 2007 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 543 2007 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 544 2007 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 545 2007 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 546 2007 Nissan Quest SE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 547 2007 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 548 2007 Nissan Titan LE Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 549 2007 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 550 2007 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 551 2007 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 552 2007 Toyota Sienna CE Mini Cargo Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 553 2007 Toyota Tundra Limited Extended Crew Cab Pickup 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 554 2006 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 555 2006 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 556 2006 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 557 2006 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 558 2006 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 559 2006 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 560 2006 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 561 2006 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 562 2006 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 563 2006 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 564 2006 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 565 2006 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 566 2006 Chevrolet Malibu LS Sedan 4-Door / 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 567 2006 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 568 2006 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 569 2006 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 570 2006 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 571 2006 Dodge Charger SE Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 572 2006 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 573 2006 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 574 2006 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 575 2006 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 576 2006 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 577 2006 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 578 2006 GMC Yukon Denali Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 579 2006 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated 580 2006 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 581 2006 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 582 2006 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 583 2006 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 584 2006 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 585 2006 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 586 2006 Infiniti G35 Base Coupe 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 587 2006 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 588 2006 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 589 2006 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 590 2006 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 591 2006 Lincoln Navigator Ultimate Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 592 2006 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 593 2006 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 594 2006 Mitsubishi Eclipse GS Hatchback 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 595 2006 Mitsubishi Galant LS Sedan 4-Door / 3.8L 3828CC 230Cu. In. V6 GAS SOHC Naturally Aspirated 596 2006 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 597 2006 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 598 2006 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 599 2006 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 600 2006 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 601 2006 Nissan Titan LE Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 602 2006 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 603 2006 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 604 2006 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 605 2006 Toyota Sienna LE Mini Passenger Van 5-Door / 3.3L 3300CC 202Cu. In. V6 GAS DOHC Naturally Aspirated 606 2006 Toyota Tundra SR5 Extended Cab Pickup 4-Door / 4.0L 3956CC 241Cu. In. V6 GAS DOHC Naturally Aspirated 607 2005 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 608 2005 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 609 2005 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 610 2005 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 611 2005 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 612 2005 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 613 2005 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 614 2005 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 615 2005 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 616 2005 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 617 2005 Chevrolet Impala LS Sedan 4-Door / 3.8L 3800CC 231Cu. In. V6 GAS OHV Naturally Aspirated 618 2005 Chevrolet Malibu LS Sedan 4-Door / 3.5L 213Cu. In. V6 GAS OHV Naturally Aspirated 619 2005 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 620 2005 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 621 2005 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 622 2005 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 623 2005 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 624 2005 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 625 2005 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 626 2005 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 627 2005 GMC Yukon Denali Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 628 2005 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 629 2005 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 630 2005 Honda Odyssey LX Mini Passenger Van 5-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 631 2005 Honda Pilot LX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 632 2005 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 633 2005 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 634 2005 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 635 2005 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 636 2005 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 637 2005 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 638 2005 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 639 2005 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 640 2005 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 641 2005 Nissan Altima S Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 642 2005 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 643 2005 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 644 2005 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 645 2005 Nissan Quest SE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 646 2005 Toyota Sequoia SR5 Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 647 2005 Toyota Sienna LE Mini Passenger Van 5-Door / 3.3L 3300CC 202Cu. In. V6 GAS DOHC Naturally Aspirated 648 2005 Toyota Tundra Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 649 2004 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 650 2004 Acura RSX Base Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 651 2004 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 652 2004 Cadillac CTS Base Sedan 4-Door / 3.2L 197Cu. In. V6 GAS DOHC Naturally Aspirated 653 2004 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 654 2004 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 323Cu. In. V8 GAS OHV Naturally Aspirated 655 2004 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 656 2004 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 657 2004 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 658 2004 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 659 2004 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated 660 2004 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 661 2004 Honda Odyssey EX Mini Passenger Van 5-Door / 3.5L 3474CC V6 GAS SOHC Naturally Aspirated 662 2004 Honda Pilot LX Sport Utility 4-Door / 3.5L 3475CC V6 GAS SOHC Naturally Aspirated 663 2004 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 664 2004 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 665 2004 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 666 2004 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 667 2004 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 668 2004 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 669 2004 Nissan Quest S Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 670 2003 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 671 2003 Cadillac CTS Base Sedan 4-Door / 3.2L 197Cu. In. V6 GAS DOHC Naturally Aspirated 672 2003 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 673 2003 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 GAS OHV Naturally Aspirated 674 2003 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 675 2003 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 676 2003 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated 677 2003 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 678 2003 Honda Pilot LX Sport Utility 4-Door / 3.5L 3475CC V6 GAS SOHC Naturally Aspirated 679 2003 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 680 2003 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 681 2003 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 682 2002 Acura RSX Base Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 683 2002 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 684 2002 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 685 2002 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 686 2002 Honda Accord EX Coupe 2-Door / 2.3L 2254CC l4 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.3L 2254CC l4 GAS SOHC Naturally Aspirated Shipping This product is warehoused in California, USA. We will be shipping out the item within 1 business day. If you make an order and pay before 1 pm PST on business day, we will most likely ship out the item the same day! USPS is our preferred carrier. The item usually arrives within 1-5 days after shipped. Other faster shipping option is available on request with additional cost. Email us for pricing to your zip code/country. We ship to PayPal confirmed address only. Please make sure your PayPal address is up-to-date. Payment We accept PayPal only. Please pay within 2 days after buying the item. Your payment is for the cost the item and the shipping & handling charges. Any custom duty or import/export fees are not included. Please consult related policy if you have any doubt. If you'd like to buy more quantity at lower wholesale price, please send us a message through Ask Seller Question link. Return If you don't like the product, you could always return it within 14 days, no questions asked. Buyer is responsible for the return shipping costs. Please do let us know if you have any question regarding the item. We try our best to resolve any issue. We are committed to provide 100% customer satisfaction. in title & description 24, 37, 73, 74, T5 2825, 168, 194, W5W 906, 912, 921, W16W BA9s, 64111, 64132 DE3175, DE3022 6411, 6413, 6418 DE3423, DE3425, C5W 560, 569, 578 211-2, 212-2, 214-2 3157, 3457, 4157, 3156 1156, 1157, 2357, 7506 7440, 7441, 7443, T20 D1S, D3S D2S, D2R, D4S, D4R H1, H3, H4, H7 H11, H8, H9 9005, HB3, 9145, H10 9006, 9012, HB4 880, 5202, H16, P13W Universal Fit Size
(6) Xenon Blue 3-SMD 6641 LED Bulbs For Car Sun Visor Vanity Mirror Lights
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
(6) Xenon Blue 3-SMD 6641 LED Bulbs For Car Sun Visor Vanity Mirror Lights Description This auction features 3 pairs*Blue*3-SMD D29mm LED Bulbs for vanity mirror lights The 3-SMD Fuse shape D29mm LED bulb will replace the stock 6614F and TS-14V1CP bulb and will fit the Acura, Honda, Infiniti, Nissan, Toyota, Subaru, Mazda, Mitsubishi, etc in the parts compatibility list. Features: * *Size: 1.15" (29mm) long * *Super*Blue* * *3 pieces super bright 3-Emitter 5050 SMD on each bulb * *Voltage: 12V * *Lifespan: 30000 working hours * *Low current consumption * *Fits part numbers 6614, 6614F, F30-WHP*and TS-14V1CP bulbs * *This LED bulb is polar sensitive, so in case the bulb won't light up, please flip it 180 degrees Fitment IMPORTANT Fitment information provided is for reference only. Please make sure to match the exact part numbers between this part and the part that you are replacing. Contact your mechanics, or send us a message to make sure it matches exactly in case of doubt before purchasing. Seller is not responsible if you are buying non-matching parts. # Notes Year Make Model Trim / Engine 1 2014 Acura ILX Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS SOHC Naturally Aspirated Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated Hybrid Sedan 4-Door / 1.5L 1497CC l4 ELECTRIC/GAS SOHC Naturally Aspirated 2 2014 Acura RDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 3 2014 Acura RLX Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 4 2014 Cadillac ATS Base / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Base / 2.5L 2457CC 150Cu. In. l4 GAS N/R Naturally Aspirated Luxury / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Luxury / 2.5L 2457CC 150Cu. In. l4 GAS N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Performance / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Performance / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Premium / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Premium / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated 5 2014 Cadillac CTS Base / 2.0L 1998CC 122Cu. In. l4 GAS N/R Turbocharged Base / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Vsport / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled 6 2014 Cadillac SRX Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Luxury Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Performance Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated Premium Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 7 2014 Cadillac XTS Base / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Luxury / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled Platinum / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Platinum / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled Premium / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated Premium / 3.6L 217Cu. In. V6 GAS N/R Turbo/Intercooled 8 2014 Chevrolet Equinox LS / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LT / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LT / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated LTZ / 2.4L 145Cu. In. l4 FLEX N/R Naturally Aspirated LTZ / 3.6L 217Cu. In. V6 FLEX N/R Naturally Aspirated 9 2014 Chevrolet Impala Eco Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated LS Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LT Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LT Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated LTZ Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated LTZ Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 10 2014 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 11 2014 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SE Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated SE Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SXT Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 12 2014 Dodge Durango Citadel Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated Citadel Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated Limited Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated Limited Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated Rallye Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated SXT Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 13 2014 Ford C-Max Energi / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated Hybrid SE / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated Hybrid SEL / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS N/R Naturally Aspirated 14 2014 Ford Escape S Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated SE Sport Utility 4-Door / 1.6L 1601CC 98Cu. In. l4 GAS DOHC Turbocharged SE Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Titanium Sport Utility 4-Door / 1.6L 1601CC 98Cu. In. l4 GAS DOHC Turbocharged Titanium Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged 15 2014 Ford Explorer Base Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Base Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Limited Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Sport Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Sport Utility 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 16 2014 Ford Flex Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated Limited Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated SEL Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated SEL Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 17 2014 Ford Fusion Energi SE Luxury Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated Energi Titanium Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated S Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated S Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated SE Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated SE Sedan 4-Door / 1.6L 1596CC 97Cu. In. l4 GAS DOHC Turbocharged SE Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged SE Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Titanium Hybrid Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated Titanium Sedan 4-Door / 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged 18 2014 GMC Acadia Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated SLE Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 19 2014 GMC Sierra 1500 Base Crew Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated Base Extended Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated Base Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated Base Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Crew Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Extended Cab Pickup 4-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLE Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 FLEX OHV Naturally Aspirated SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Crew Cab Pickup 4-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated SLT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Extended Cab Pickup 4-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated SLT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated SLT Standard Cab Pickup 2-Door / 6.2L 6162CC 376Cu. In. V8 FLEX OHV Naturally Aspirated 20 2014 GMC Terrain Denali Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated SLE Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated SLT Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 21 2014 Honda Accord Plug-In Sedan 4-Door / 2.0L 1993CC 122Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 22 2014 Infiniti Q50 Base / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Hybrid Premium / 3.5L 3498CC V6 ELECTRIC/GAS N/R Naturally Aspirated Hybrid Sport / 3.5L 3498CC V6 ELECTRIC/GAS N/R Naturally Aspirated Premium / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Sport / 3.7L 3696CC V6 GAS N/R Naturally Aspirated 23 2014 Infiniti QX80 Base / 5.6L 5552CC V8 GAS N/R Naturally Aspirated 24 2014 Mazda 6 Grand Touring Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Touring Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 25 2014 Mazda CX-5 Grand Touring Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated Sport Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated Touring Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 26 2014 Nissan 370Z Base / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Nismo / 3.7L 3696CC V6 GAS N/R Naturally Aspirated Touring / 3.7L 3696CC V6 GAS N/R Naturally Aspirated 27 2014 Nissan GT-R Black Edition Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged Track Edition Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 28 2014 Nissan Murano CrossCabriolet Convertible 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 29 2013 Acura ILX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 30 2013 Acura RDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 31 2013 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 32 2013 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 33 2013 Buick LaCrosse Base Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 34 2013 Cadillac ATS Base Sedan 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged 35 2013 Chevrolet Impala LS Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 36 2013 Chevrolet Malibu LS Sedan 4-Door / 2.5L 2457CC 153Cu. In. l4 GAS DOHC Naturally Aspirated 37 2013 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 38 2013 Chrysler 200 LX Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 39 2013 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 40 2013 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 41 2013 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 42 2013 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 43 2013 Dodge Dart SE Sedan 4-Door / 2.0L 1995CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 44 2013 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 45 2013 Dodge Journey SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 46 2013 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 47 2013 Ford Escape S Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 48 2013 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX N/R Naturally Aspirated 49 2013 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 50 2013 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 51 2013 Ford Mustang Base Coupe 2-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 52 2013 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 53 2013 GMC Terrain Denali Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 54 2013 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 55 2013 Infiniti EX37 Base Sport Utility 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 56 2013 Infiniti FX37 Base Sport Utility 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 57 2013 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 58 2013 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 59 2013 Infiniti JX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 60 2013 Infiniti M35h Base Sedan 4-Door / 3.5L 3498CC V6 ELECTRIC/GAS DOHC Naturally Aspirated 61 2013 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 62 2013 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 63 2013 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 64 2013 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 65 2013 Mazda CX-5 Sport Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 66 2013 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 67 2013 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 68 2013 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 69 2013 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 70 2013 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 71 2013 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 72 2013 Subaru BRZ Limited Coupe 2-Door / 2.0L 1998CC 122Cu. In. H4 GAS DOHC Naturally Aspirated Premium Coupe 2-Door / 2.0L 1998CC 122Cu. In. H4 GAS DOHC Naturally Aspirated 73 2013 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 74 2013 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2498CC 152Cu. In. H4 GAS DOHC Naturally Aspirated 75 2013 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2498CC 152Cu. In. H4 GAS DOHC Naturally Aspirated 76 2013 Toyota Land Cruiser Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 77 2013 Toyota Sienna Base Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 78 2013 Volvo XC90 3.2 Sport Utility 4-Door / 3.2L 3192CC l6 GAS DOHC Naturally Aspirated 79 2012 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 80 2012 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 81 2012 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 82 2012 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 83 2012 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 84 2012 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 85 2012 Buick Enclave Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 86 2012 Buick LaCrosse Base Sedan 4-Door / 2.4L 2384CC 145Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 87 2012 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 88 2012 Cadillac SRX Base Sport Utility 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 89 2012 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 90 2012 Chevrolet Cruze LS Sedan 4-Door / 1.8L 1796CC 110Cu. In. l4 GAS DOHC Naturally Aspirated 91 2012 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated 92 2012 Chevrolet Impala LS Sedan 4-Door / 3.6L 217Cu. In. V6 FLEX DOHC Naturally Aspirated 93 2012 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 94 2012 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 95 2012 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 96 2012 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 97 2012 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 98 2012 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 99 2012 Chrysler 200 LX Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 100 2012 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 101 2012 Dodge Avenger R/T Sedan 4-Door / 3.6L 3604CC 220Cu. In. V6 FLEX DOHC Naturally Aspirated 102 2012 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 103 2012 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 104 2012 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 105 2012 Dodge Journey SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 106 2012 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 107 2012 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 108 2012 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 109 2012 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 110 2012 Ford F-150 XL Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 111 2012 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 112 2012 Ford Focus S Sedan 4-Door / 2.0L 121Cu. In. l4 GAS DOHC Naturally Aspirated 113 2012 Ford Mustang Base Coupe 2-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 114 2012 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 115 2012 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 116 2012 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 117 2012 GMC Terrain SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 FLEX DOHC Naturally Aspirated 118 2012 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 119 2012 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 120 2012 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 121 2012 Honda CR-Z Base Hatchback 2-Door / 1.5L 1497CC 91Cu. In. l4 ELECTRIC/GAS SOHC Naturally Aspirated 122 2012 Honda Crosstour EX Hatchback 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 123 2012 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 124 2012 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 125 2012 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 126 2012 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 127 2012 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 128 2012 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 129 2012 Infiniti G25 Base Sedan 4-Door / 2.5L 2496CC 152Cu. In. V6 GAS DOHC Naturally Aspirated 130 2012 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 131 2012 Infiniti M35h Base Sedan 4-Door / 3.5L 3498CC V6 ELECTRIC/GAS DOHC Naturally Aspirated 132 2012 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 133 2012 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 134 2012 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 135 2012 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 136 2012 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 137 2012 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 138 2012 Lexus IS250 C Convertible 2-Door / 2.5L 2499CC V6 GAS DOHC Naturally Aspirated 139 2012 Lexus IS350 C Convertible 2-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 140 2012 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 141 2012 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 142 2012 Lincoln MKX Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 143 2012 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 144 2012 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 145 2012 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 146 2012 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 147 2012 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 148 2012 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 149 2012 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 150 2012 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 151 2012 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 152 2012 Mitsubishi Outlander Sport ES Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 153 2012 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 154 2012 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 155 2012 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 156 2012 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 157 2012 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 158 2012 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 159 2012 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 160 2012 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 161 2012 Nissan Titan SL Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 162 2012 Ram 1500 Tradesman Crew Cab Pickup 4-Door / 4.7L 285Cu. In. V8 FLEX SOHC Naturally Aspirated 163 2012 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 164 2012 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 165 2012 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 166 2012 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 FLEX DOHC Naturally Aspirated 167 2012 Toyota Sienna Base Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 168 2012 Volvo C30 T5 Hatchback 2-Door / 2.5L 2521CC l5 GAS DOHC Turbocharged 169 2012 Volvo S60 T5 Sedan 4-Door / 2.5L 2521CC l5 GAS DOHC Turbocharged 170 2012 Volvo XC90 3.2 Sport Utility 4-Door / 3.2L 3192CC l6 GAS DOHC Naturally Aspirated 171 2011 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 172 2011 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 173 2011 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 174 2011 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 175 2011 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 176 2011 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 177 2011 Buick Enclave CX Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 178 2011 Buick LaCrosse CXL Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 179 2011 Cadillac CTS Base Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 180 2011 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 181 2011 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 182 2011 Cadillac SRX Base Sport Utility 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 183 2011 Cadillac STS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 184 2011 Chevrolet Avalanche LS Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 185 2011 Chevrolet Cruze LS Sedan 4-Door / 1.8L 1796CC 110Cu. In. l4 GAS DOHC Naturally Aspirated 186 2011 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 2384CC 145Cu. In. l4 GAS DOHC Naturally Aspirated 187 2011 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 188 2011 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 189 2011 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 190 2011 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 191 2011 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 192 2011 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 193 2011 Chevrolet Volt Base Hatchback 4-Door / 1.4L 1398CC 85Cu. In. l4 ELECTRIC/GAS DOHC Naturally Aspirated 194 2011 Chrysler 200 LX Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 195 2011 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 196 2011 Dodge Avenger Express Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 197 2011 Dodge Challenger SRT8 Coupe 2-Door / 6.4L 6424CC 392Cu. In. V8 GAS OHV Naturally Aspirated 198 2011 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 199 2011 Dodge Durango R/T Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 200 2011 Dodge Nitro Heat Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 201 2011 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 202 2011 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 203 2011 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 204 2011 Ford Explorer XLT Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 205 2011 Ford F-150 XL Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged XLT Standard Cab Pickup 2-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Turbocharged 206 2011 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 207 2011 Ford Focus S Sedan 4-Door / 2.0L 121Cu. In. l4 GAS DOHC Naturally Aspirated 208 2011 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 209 2011 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 210 2011 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 211 2011 GMC Terrain SLE Sport Utility 4-Door / 3.0L 182Cu. In. V6 FLEX DOHC Naturally Aspirated 212 2011 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 213 2011 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 214 2011 Honda Accord Crosstour EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 215 2011 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 216 2011 Honda CR-Z Base Hatchback 2-Door / 1.5L 1497CC 91Cu. In. l4 ELECTRIC/GAS SOHC Naturally Aspirated 217 2011 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 218 2011 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 219 2011 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 220 2011 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 221 2011 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 222 2011 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 223 2011 Infiniti G25 Base Sedan 4-Door / 2.5L 2496CC 152Cu. In. V6 GAS DOHC Naturally Aspirated 224 2011 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 225 2011 Infiniti M37 Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 226 2011 Infiniti M56 Base Sedan 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 227 2011 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 228 2011 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 229 2011 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 230 2011 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 231 2011 Lexus IS250 C Convertible 2-Door / 2.5L 2499CC V6 GAS DOHC Naturally Aspirated 232 2011 Lexus IS350 C Convertible 2-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 233 2011 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 234 2011 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 235 2011 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 236 2011 Lincoln MKX Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 237 2011 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 238 2011 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 239 2011 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 240 2011 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 241 2011 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 242 2011 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 243 2011 Mazda RX-8 Sport Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 244 2011 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 245 2011 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 246 2011 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 247 2011 Mitsubishi Outlander Sport ES Sport Utility 4-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 248 2011 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 249 2011 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 250 2011 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 251 2011 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 252 2011 Nissan Murano SV Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 253 2011 Nissan Quest LE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 254 2011 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 255 2011 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 256 2011 Nissan Titan SL Crew Cab Pickup 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 257 2011 Ram 1500 Laramie Extended Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 258 2011 Ram Dakota ST Extended Cab Pickup 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 259 2011 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 260 2011 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 261 2011 Subaru Outback 2.5i Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 262 2011 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 FLEX DOHC Naturally Aspirated 263 2011 Toyota Sienna Limited Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 264 2010 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 265 2010 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 266 2010 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 267 2010 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 268 2010 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 269 2010 Acura ZDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 270 2010 Buick Enclave CX Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 271 2010 Buick LaCrosse CXL Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 272 2010 Cadillac CTS Base Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 273 2010 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 274 2010 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 275 2010 Cadillac SRX Base Sport Utility 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated 276 2010 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 277 2010 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 278 2010 Chevrolet Equinox LS Sport Utility 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 279 2010 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 280 2010 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 281 2010 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 282 2010 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 283 2010 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 284 2010 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 285 2010 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 286 2010 Dodge Avenger R/T Sedan 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 287 2010 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 288 2010 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 289 2010 Dodge Nitro SE Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 290 2010 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 291 2010 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 292 2010 Ford Escape XLT Sport Utility 4-Door / 3.0L 183Cu. In. V6 FLEX DOHC Naturally Aspirated 293 2010 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 294 2010 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 295 2010 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 296 2010 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 297 2010 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 298 2010 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 299 2010 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 300 2010 GMC Terrain SLE Sport Utility 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 301 2010 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 302 2010 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 303 2010 Honda Accord Crosstour EX Hatchback 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 304 2010 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 305 2010 Honda Odyssey EX-L Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 306 2010 Honda Pilot LX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 307 2010 Honda Ridgeline RTS Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 308 2010 Infiniti EX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 309 2010 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 310 2010 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 311 2010 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 312 2010 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 313 2010 Jeep Commander Sport Sport Utility 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 314 2010 Jeep Compass Limited Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 315 2010 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 316 2010 Land Rover Range Rover HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 317 2010 Land Rover Range Rover Sport HSE Sport Utility 4-Door / 5.0L 5000CC V8 GAS DOHC Naturally Aspirated 318 2010 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 319 2010 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 320 2010 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 321 2010 Lincoln MKT Base Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 322 2010 Lincoln MKX Base Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 323 2010 Lincoln MKZ Base Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 324 2010 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 325 2010 Mazda 3 i Sedan 4-Door / 2.0L 2000CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 326 2010 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 327 2010 Mazda CX-7 Sport Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 328 2010 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 329 2010 Mazda RX-8 Grand Touring Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 330 2010 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 331 2010 Mitsubishi Endeavor LS Sport Utility 4-Door / 3.8L 3828CC 230Cu. In. V6 GAS SOHC Naturally Aspirated 332 2010 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 333 2010 Mitsubishi Outlander ES Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 334 2010 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 335 2010 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 336 2010 Nissan Armada SE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 337 2010 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 338 2010 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 339 2010 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 340 2010 Nissan Rogue S Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 341 2010 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 342 2010 Nissan Titan PRO-4X Extended Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 343 2010 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 344 2010 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 345 2010 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 346 2010 Toyota Sienna XLE Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 347 2010 Toyota Tundra SR5 Crew Cab Pickup 4-Door / 4.6L 4608CC V8 GAS DOHC Naturally Aspirated 348 2009 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 349 2009 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 350 2009 Acura RL Base Sedan 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 351 2009 Acura TL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 352 2009 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 353 2009 Cadillac CTS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 354 2009 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 355 2009 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 356 2009 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 357 2009 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 358 2009 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 359 2009 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 360 2009 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 361 2009 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 362 2009 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 363 2009 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 364 2009 Chevrolet Tahoe LS Sport Utility 4-Door / 4.8L 294Cu. In. V8 GAS OHV Naturally Aspirated 365 2009 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 366 2009 Chevrolet Traverse LS Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 367 2009 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 368 2009 Dodge Avenger R/T Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 369 2009 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 370 2009 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 371 2009 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 372 2009 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 373 2009 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 374 2009 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 375 2009 Ford Escape XLT Sport Utility 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 376 2009 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 377 2009 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 378 2009 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 379 2009 Ford Flex SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 380 2009 Ford Taurus SE Sedan 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 381 2009 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 382 2009 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 383 2009 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 384 2009 GMC Yukon Denali Sport Utility 4-Door / 6.2L 376Cu. In. V8 FLEX OHV Naturally Aspirated 385 2009 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 386 2009 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 387 2009 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 388 2009 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 389 2009 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 390 2009 Infiniti EX35 Journey Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 391 2009 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 392 2009 Infiniti FX50 Base Sport Utility 4-Door / 5.0L 5026CC V8 GAS DOHC Naturally Aspirated 393 2009 Infiniti G37 Base Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Convertible 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 394 2009 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 395 2009 Jeep Commander Sport Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 396 2009 Jeep Compass Limited Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 397 2009 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 3.0L 2985CC 182Cu. In. V6 DIESEL DOHC Turbocharged 398 2009 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 399 2009 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 400 2009 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 401 2009 Lincoln MKS Base Sedan 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 402 2009 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated 403 2009 Mazda 6 i Sedan 4-Door / 2.5L 2488CC 152Cu. In. l4 GAS DOHC Naturally Aspirated 404 2009 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 405 2009 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 406 2009 Mazda RX-8 R3 Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 407 2009 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 408 2009 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 409 2009 Mitsubishi Outlander XLS Sport Utility 4-Door / 3.0L 2998CC 182Cu. In. V6 GAS SOHC Naturally Aspirated 410 2009 Nissan 370Z Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 411 2009 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 412 2009 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 413 2009 Nissan GT-R Premium Coupe 2-Door / 3.8L 3799CC V6 GAS DOHC Turbocharged 414 2009 Nissan Maxima S Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 415 2009 Nissan Murano LE Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 416 2009 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated SL Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 417 2009 Nissan Rogue SL Sport Utility 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 418 2009 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 419 2009 Nissan Titan PRO-4X Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 420 2009 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 421 2009 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 422 2009 Toyota Sequoia Limited Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 423 2009 Toyota Sienna CE Mini Cargo Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 424 2009 Toyota Tundra SR5 Crew Cab Pickup 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 425 2008 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 426 2008 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 427 2008 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 428 2008 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 429 2008 Cadillac CTS Base Sedan 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 430 2008 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 431 2008 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 432 2008 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 433 2008 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 434 2008 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 435 2008 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 436 2008 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 437 2008 Chevrolet Malibu LS Sedan 4-Door / 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated 438 2008 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 439 2008 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 440 2008 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 441 2008 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 442 2008 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 443 2008 Dodge Avenger R/T Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 444 2008 Dodge Challenger SRT8 Coupe 2-Door / 6.1L 6059CC 370Cu. In. V8 GAS OHV Naturally Aspirated 445 2008 Dodge Charger SE Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 446 2008 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 447 2008 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 448 2008 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 449 2008 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 450 2008 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 451 2008 Ford Expedition XLT Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 452 2008 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 453 2008 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 454 2008 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 455 2008 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 456 2008 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 457 2008 GMC Yukon Denali Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 458 2008 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 459 2008 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 460 2008 Honda Odyssey EX Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 461 2008 Honda Pilot Value Package Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 462 2008 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 463 2008 Infiniti EX35 Journey Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 464 2008 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 465 2008 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 466 2008 Infiniti G35 Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 467 2008 Infiniti G37 Base Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Journey Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated Sport Coupe 2-Door / 3.7L 3696CC V6 GAS DOHC Naturally Aspirated 468 2008 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 469 2008 Jeep Commander Sport Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 470 2008 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 471 2008 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 472 2008 Lexus LX570 Base Sport Utility 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 473 2008 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 474 2008 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 475 2008 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 476 2008 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 477 2008 Mazda CX-9 Sport Sport Utility 4-Door / 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated 478 2008 Mazda RX-8 40th Anniversary Edition Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 479 2008 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 480 2008 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 481 2008 Mitsubishi Outlander SE Sport Utility 4-Door / 2.4L 2360CC 144Cu. In. l4 GAS DOHC Naturally Aspirated 482 2008 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated S Coupe 2-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 483 2008 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 484 2008 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 485 2008 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 486 2008 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 487 2008 Nissan Titan LE Extended Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 488 2008 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 489 2008 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 490 2008 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 491 2008 Toyota Sienna Limited Mini Passenger Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 492 2008 Toyota Tundra Base Standard Cab Pickup 2-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 493 2007 Acura MDX Base Sport Utility 4-Door / 3.7L 3664CC V6 GAS SOHC Naturally Aspirated 494 2007 Acura RDX Base Sport Utility 4-Door / 2.3L 2300CC l4 GAS DOHC Turbocharged 495 2007 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 496 2007 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 497 2007 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 498 2007 Cadillac DTS L Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 499 2007 Cadillac Escalade Base Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 500 2007 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 501 2007 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 502 2007 Chevrolet Avalanche LT Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 503 2007 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 504 2007 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 505 2007 Chevrolet Malibu LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 GAS OHV Naturally Aspirated 506 2007 Chevrolet Silverado 1500 LT Extended Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated LT Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 507 2007 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 508 2007 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 509 2007 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 510 2007 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 511 2007 Dodge Charger SE Sedan 4-Door / 2.7L 2700CC 167Cu. In. V6 GAS DOHC Naturally Aspirated 512 2007 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 513 2007 Dodge Nitro R/T Sport Utility 4-Door / 4.0L 3952CC 241Cu. In. V6 GAS SOHC Naturally Aspirated 514 2007 Dodge Ram 1500 Laramie Crew Cab Pickup 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 515 2007 Ford Edge SE Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 516 2007 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 517 2007 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 518 2007 Ford F-150 XL Standard Cab Pickup 2-Door / 5.4L 330Cu. In. V8 FLEX SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 519 2007 GMC Acadia SLT Sport Utility 4-Door / 3.6L 217Cu. In. V6 GAS DOHC Naturally Aspirated 520 2007 GMC Envoy Denali Sport Utility 4-Door / 5.3L 325Cu. In. V8 GAS OHV Naturally Aspirated 521 2007 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 522 2007 GMC Yukon Denali Sport Utility 4-Door / 6.2L 6199CC 378Cu. In. V8 GAS OHV Naturally Aspirated 523 2007 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated 524 2007 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 525 2007 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 526 2007 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 527 2007 Honda Ridgeline RTS Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 528 2007 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 529 2007 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 530 2007 Infiniti G35 Base Coupe 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Journey Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Sport Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 531 2007 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 532 2007 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 533 2007 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 534 2007 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 535 2007 Lincoln Navigator L Ultimate Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 536 2007 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 537 2007 Mazda CX-7 Sport Sport Utility 4-Door / 2.3L 2260CC l4 GAS DOHC Turbocharged 538 2007 Mazda CX-9 Sport Sport Utility 4-Door / 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated 539 2007 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 540 2007 Mitsubishi Eclipse GS Coupe 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 541 2007 Mitsubishi Galant ES Sedan 4-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 542 2007 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 543 2007 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 544 2007 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 545 2007 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 546 2007 Nissan Quest SE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 547 2007 Nissan Sentra Base Sedan 4-Door / 2.0L 1997CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 548 2007 Nissan Titan LE Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 549 2007 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 550 2007 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 551 2007 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 552 2007 Toyota Sienna CE Mini Cargo Van 5-Door / 3.5L 3456CC V6 GAS DOHC Naturally Aspirated 553 2007 Toyota Tundra Limited Extended Crew Cab Pickup 4-Door / 5.7L 5663CC 345Cu. In. V8 GAS DOHC Naturally Aspirated 554 2006 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 555 2006 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 556 2006 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 557 2006 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 558 2006 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 559 2006 Cadillac DTS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 560 2006 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 561 2006 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 562 2006 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 563 2006 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 564 2006 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 565 2006 Chevrolet Impala LS Sedan 4-Door / 3.5L 3490CC 213Cu. In. V6 FLEX OHV Naturally Aspirated 566 2006 Chevrolet Malibu LS Sedan 4-Door / 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated 567 2006 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 568 2006 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 569 2006 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 570 2006 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 571 2006 Dodge Charger SE Sedan 4-Door / 3.5L 3497CC 215Cu. In. V6 GAS SOHC Naturally Aspirated 572 2006 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 573 2006 Ford Escape XLT Sport Utility 4-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated 574 2006 Ford Explorer XLT Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 575 2006 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 576 2006 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 577 2006 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 5328CC 325Cu. In. V8 FLEX OHV Naturally Aspirated 578 2006 GMC Yukon Denali Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 579 2006 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2997CC V6 GAS SOHC Naturally Aspirated 580 2006 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 581 2006 Honda Odyssey Touring Mini Passenger Van 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 582 2006 Honda Pilot EX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 583 2006 Honda Ridgeline RT Crew Cab Pickup 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 584 2006 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 585 2006 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4494CC V8 GAS DOHC Naturally Aspirated 586 2006 Infiniti G35 Base Coupe 2-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated Base Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 587 2006 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 588 2006 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 589 2006 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 590 2006 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 591 2006 Lincoln Navigator Ultimate Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 592 2006 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 593 2006 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 594 2006 Mitsubishi Eclipse GS Hatchback 2-Door / 2.4L 2378CC l4 GAS SOHC Naturally Aspirated 595 2006 Mitsubishi Galant LS Sedan 4-Door / 3.8L 3828CC 230Cu. In. V6 GAS SOHC Naturally Aspirated 596 2006 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 597 2006 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 598 2006 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 599 2006 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 600 2006 Nissan Quest Base Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 601 2006 Nissan Titan LE Crew Cab Pickup 4-Door / 5.6L 5552CC V8 FLEX DOHC Naturally Aspirated 602 2006 Subaru Impreza WRX Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Turbocharged 603 2006 Subaru Legacy 2.5i Sedan 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 604 2006 Toyota Sequoia Limited Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 605 2006 Toyota Sienna LE Mini Passenger Van 5-Door / 3.3L 3300CC 202Cu. In. V6 GAS DOHC Naturally Aspirated 606 2006 Toyota Tundra SR5 Extended Cab Pickup 4-Door / 4.0L 3956CC 241Cu. In. V6 GAS DOHC Naturally Aspirated 607 2005 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 608 2005 Acura RL Base Sedan 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 609 2005 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 610 2005 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 611 2005 Cadillac CTS Base Sedan 4-Door / 2.8L 2792CC 170Cu. In. V6 GAS DOHC Naturally Aspirated 612 2005 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 613 2005 Cadillac SRX Base Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 614 2005 Cadillac STS Base Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 615 2005 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 616 2005 Chevrolet Equinox LS Sport Utility 4-Door / 3.4L 207Cu. In. V6 GAS OHV Naturally Aspirated 617 2005 Chevrolet Impala LS Sedan 4-Door / 3.8L 3800CC 231Cu. In. V6 GAS OHV Naturally Aspirated 618 2005 Chevrolet Malibu LS Sedan 4-Door / 3.5L 213Cu. In. V6 GAS OHV Naturally Aspirated 619 2005 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 620 2005 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 621 2005 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 622 2005 Chrysler 300 C Sedan 4-Door / 5.7L 345Cu. In. V8 GAS OHV Naturally Aspirated 623 2005 Dodge Durango SLT Sport Utility 4-Door / 3.7L 226Cu. In. V6 GAS SOHC Naturally Aspirated 624 2005 Ford F-150 XL Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 625 2005 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 626 2005 GMC Sierra 1500 SLE Standard Cab Pickup 2-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 627 2005 GMC Yukon Denali Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 628 2005 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 629 2005 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 630 2005 Honda Odyssey LX Mini Passenger Van 5-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 631 2005 Honda Pilot LX Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 632 2005 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 633 2005 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 634 2005 Infiniti QX56 Base Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 635 2005 Jeep Grand Cherokee Laredo Sport Utility 4-Door / 4.7L 285Cu. In. V8 GAS SOHC Naturally Aspirated 636 2005 Lexus GX470 Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 637 2005 Lexus SC430 Base Convertible 2-Door / 4.3L 4293CC V8 GAS DOHC Naturally Aspirated 638 2005 Lincoln Navigator Base Sport Utility 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 639 2005 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 640 2005 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 641 2005 Nissan Altima S Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 642 2005 Nissan Armada LE Sport Utility 4-Door / 5.6L 5552CC V8 GAS DOHC Naturally Aspirated 643 2005 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 644 2005 Nissan Murano SL Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 645 2005 Nissan Quest SE Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 646 2005 Toyota Sequoia SR5 Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 647 2005 Toyota Sienna LE Mini Passenger Van 5-Door / 3.3L 3300CC 202Cu. In. V6 GAS DOHC Naturally Aspirated 648 2005 Toyota Tundra Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 649 2004 Acura MDX Base Sport Utility 4-Door / 3.5L 3471CC V6 GAS SOHC Naturally Aspirated 650 2004 Acura RSX Base Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 651 2004 Acura TSX Base Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 652 2004 Cadillac CTS Base Sedan 4-Door / 3.2L 197Cu. In. V6 GAS DOHC Naturally Aspirated 653 2004 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 654 2004 Chevrolet Avalanche 1500 Z66 Crew Cab Pickup 4-Door / 5.3L 323Cu. In. V8 GAS OHV Naturally Aspirated 655 2004 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 656 2004 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 657 2004 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 658 2004 GMC Envoy SLE Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 659 2004 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated 660 2004 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 661 2004 Honda Odyssey EX Mini Passenger Van 5-Door / 3.5L 3474CC V6 GAS SOHC Naturally Aspirated 662 2004 Honda Pilot LX Sport Utility 4-Door / 3.5L 3475CC V6 GAS SOHC Naturally Aspirated 663 2004 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 664 2004 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 665 2004 Mazda 6 i Sedan 4-Door / 2.3L 2260CC l4 GAS DOHC Naturally Aspirated 666 2004 Mazda RX-8 Base Coupe 4-Door / 1.3L 1308CC R2 GAS N/R Naturally Aspirated 667 2004 Nissan Altima Base Sedan 4-Door / 2.5L 2500CC l4 GAS DOHC Naturally Aspirated 668 2004 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 669 2004 Nissan Quest S Mini Passenger Van 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 670 2003 Acura RSX Type-S Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 671 2003 Cadillac CTS Base Sedan 4-Door / 3.2L 197Cu. In. V6 GAS DOHC Naturally Aspirated 672 2003 Cadillac Escalade Base Sport Utility 4-Door / 6.0L 5967CC 364Cu. In. V8 GAS OHV Naturally Aspirated 673 2003 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 GAS OHV Naturally Aspirated 674 2003 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 675 2003 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 676 2003 Honda Accord EX Coupe 2-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Coupe 2-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated EX Sedan 4-Door / 3.0L 2977CC V6 GAS SOHC Naturally Aspirated 677 2003 Honda CR-V EX Sport Utility 4-Door / 2.4L 2354CC l4 GAS DOHC Naturally Aspirated 678 2003 Honda Pilot LX Sport Utility 4-Door / 3.5L 3475CC V6 GAS SOHC Naturally Aspirated 679 2003 Infiniti FX35 Base Sport Utility 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 680 2003 Infiniti FX45 Base Sport Utility 4-Door / 4.5L 4500CC V8 GAS DOHC Naturally Aspirated 681 2003 Nissan Maxima SE Sedan 4-Door / 3.5L 3498CC V6 GAS DOHC Naturally Aspirated 682 2002 Acura RSX Base Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 683 2002 Chevrolet Suburban 1500 LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 684 2002 Chevrolet Tahoe LS Sport Utility 4-Door / 5.3L 323Cu. In. V8 FLEX OHV Naturally Aspirated 685 2002 Chevrolet Trailblazer LT Sport Utility 4-Door / 4.2L 256Cu. In. l6 GAS DOHC Naturally Aspirated 686 2002 Honda Accord EX Coupe 2-Door / 2.3L 2254CC l4 GAS SOHC Naturally Aspirated EX Sedan 4-Door / 2.3L 2254CC l4 GAS SOHC Naturally Aspirated Shipping This product is warehoused in California, USA. We will be shipping out the item within 1 business day. If you make an order and pay before 1 pm PST on business day, we will most likely ship out the item the same day! USPS is our preferred carrier. The item usually arrives within 1-5 days after shipped. Other faster shipping option is available on request with additional cost. Email us for pricing to your zip code/country. We ship to PayPal confirmed address only. Please make sure your PayPal address is up-to-date. Payment We accept PayPal only. Please pay within 2 days after buying the item. Your payment is for the cost the item and the shipping & handling charges. Any custom duty or import/export fees are not included. Please consult related policy if you have any doubt. If you'd like to buy more quantity at lower wholesale price, please send us a message through Ask Seller Question link. Return If you don't like the product, you could always return it within 14 days, no questions asked. Buyer is responsible for the return shipping costs. Please do let us know if you have any question regarding the item. We try our best to resolve any issue. We are committed to provide 100% customer satisfaction. in title & description 24, 37, 73, 74, T5 2825, 168, 194, W5W 906, 912, 921, W16W BA9s, 64111, 64132 DE3175, DE3022 6411, 6413, 6418 DE3423, DE3425, C5W 560, 569, 578 211-2, 212-2, 214-2 3157, 3457, 4157, 3156 1156, 1157, 2357, 7506 7440, 7441, 7443, T20 D1S, D3S D2S, D2R, D4S, D4R H1, H3, H4, H7 H11, H8, H9 9005, HB3, 9145, H10 9006, 9012, HB4 880, 5202, H16, P13W Universal Fit Size
