Thanks man!Thanks man!!! I can always count on you to find these great vids!!![]()
That's the first time I've heard that the torque will be "450 plus" for the hybrid. The literature on the Infiniti site still only lists it at around 269.
269 is the hp of the 3.5 gasoline engine only, not the combined gas/electric.
Infiniti doesn't actually list the torque numbers for the M35h ... And that is because the peak torque from the electric motor which is avail from 0 RPM doesn't intersect in the powerband with the peak torque from 3.5L gas motor ... But rough estimates put it around 400-420 FT-LBS of torque according to media outlets ....That's the first time I've heard that the torque will be "450 plus" for the hybrid. The literature on the Infiniti site still only lists it at around 269.
You sir are incorrect!269 is the hp of the 3.5 gasoline engine only, not the combined gas/electric.
Also correct this is why the M35H and Q50 H are and will be beasts biggest complaints from current G owners is the lack of bottom end torque and the electric motor fills that void....I thought the 3.5 liter gas engine had 302 hp and 258 lb torque.
You sir are correct!
I also thought that I read somewhere that the 50kW electric motor could produce 199 lb torque.
You're welcome! I try to share wat I can and being so excited for this car i just happen to check on q50 vids a lot....obsessively!Nice find. Appreciate you sharing them!
The exhaust is definitely something that I want to hear as well! wrrrrrrrrrrrrrrr!!!!awesome videos.
im dying to hear how the exhaust sounds
I think infiniti is one of the first to break the barrier and have that much horsepower for a hybrid. This is good since it might take the thought of people thinking of hybrid to be in the power range of a toyota prius.That's the first time I've heard that the torque will be "450 plus" for the hybrid. The literature on the Infiniti site still only lists it at around 269.
