Going through the manual, I came across the following:
1) The car has two air filters under the hood(you'll see their placement in the schematic of the engine bay). What is that second filter for?
2) The inverter fluid gets changed after 15 years/125,000 miles. What the heck is inverter fluid?
3) The coolant/antifreeze is good for 7 years/105,000 miles. Really? I thought it had to be changed way before then.
4) According to the maintenance booklet, the automatic transmission fluid NEVER needs to be checked. Even though it is obviously a closed system, I would think that it would need to be changed at some point. Anyone here with technical expertise who can explain?
