Altima advertises that, but I've never seen that mentioned in any Infiniti ad. Where in the InTouch do you find the "fill-up tire mode?"Did you guys see that you can put your car in "fill-up tire mode", and it will honk at you once you've put enough air in each tire.
I think the temperature has to do with the inaccurate readings as the pressure flucuates have you guys noticed any changes in the morning when the cars been sitting?35 psi
As stated in the center screen, on the driver's side door sticker, and the owner's manual![]()
yes, in touch you can setup for 'tire fill' and once the tire reaches 35psi, the car will blinks and beeps.By the way, at the dealership yesterday, they told me that the Q50 also beeps when putting air in the tires(when it reaches the required air pressure). They said that it is also on the QX60 and QX80. I don't know that for sure, but they said it's automatic, and does not have to be set up. Again, I have no clue(after all, it IS technology.)
That is a good idea if it is to build a seasonal test thread.Also it would be interesting to hear from anyone that has Nitrogen filled tires.A bunch of us should give it a shot to know just how much the tpms is off by.
- How it Works -By the way, at the dealership yesterday, they told me that the Q50 also beeps when putting air in the tires(when it reaches the required air pressure).
I haven't checked with a manual gauge, but if the TPMS is correct, isn't the pressure a little too high in all 4 of my tires?
The TPMS has been reading pretty much the same since delivery of the car.
Thanks
