1 - 20 of 23 Posts
2022 Q50 Luxe AWD
So I got the ADD W1 v3.3 installed today. I have pics and a video, and some questions. Mods feel free to move this if it is in the wrong area, or just delete it I guess if there are already like 40 similar threads and nobody wants to see another one.
Well anyhow, here we are:
Hood Motor vehicle Automotive tire Automotive exterior Auto part
Automotive tire Motor vehicle Automotive design Helmet Hood
Motor vehicle Automotive exterior Gas Auto part Hood
Automotive tire Tire Motor vehicle Hood Audio equipment
Motor vehicle Gas Machine Nut Auto part
Motor vehicle Black Wood Automotive tire Auto part
2022 Q50 Luxe AWD
Discussion Starter · #2 ·
It looks as though both driver and passenger side PCV venting are accounted for. There is a tiny air filter thingy which I don't know the purpose of...anyone know what this is for? Do I need to change the filter? Also is it normal to be able to hear the vacuum when the engine is running? I hear it WHOOOSHing, so hopefully that is not indicative of a vacuum leak. If you look closely at the photos you might make out some zip ties and also hoses pressed against the engine itself. I plan to address this by ordering mounting brackets.
2022 Q50 Luxe AWD
Discussion Starter · #4 · (Edited)
* Edit: I reuploaded the video after flipping it the corrct way*
The video uploaded upside down for some reason, lol. I'll clean up the zip ties and tubing later with brackets. I don't like where they touch the engine.
The whoosh is likely from the breather. My question is, why is there a breather, and how is that going to effect manifold pressure if at all? My mishimoto OCC doesn’t have one and from what I can tell, the system doesn’t need one and in all likelihood shouldn’t have one. You may want to do a bit of research on this topic.
2022 Q50 Luxe AWD
Yeah I will do some poking about and see what I can find. The ADD W1 3.3 came with one, so they installed it. From what I can tell, it is hooked up as follows. The input to the can is connected to the PCV hose on the drivers valve cover. One of the outputs is connected to the intake manifold, which Im assuming will drag stuff out of the PCV line at idle as it would be under vacuum. But under boost/load, there'd need to be a different vacuum source then the manifold. I'm guessing that's the point of the second output from the can. It is connected to a small tube on the intake portion of the passengers side turbo, which would be a source of vacuum under load. But, the nozzle the hose is connected to is part of the intake which means it was always there, which means something used to be connected to it before they installed the catchcan. My guess is the breather might be connected to that, or something else on the passengers side valve cover, but I can't quite see to be sure.
Interesting design. Let us know what you discover when you dig into the reason for this design! I’m really curious about it.
Reactions: RaceCar
2022 Q50 Luxe AWD
Discussion Starter · #8 ·
Ahh, deus ex machina, lol. The dealer service manager literally just answered my question. Here is the reply:
"The passenger side is a crank case vent because there is no valve on that side and they design it to just vent to the atmosphere. I would just look at that filter and replace as needed. Maybe order one as a spare when you order the clamps just so you have it available when needed if you are in for an oil change."
So my guess based on that is maybe the conpressor/intake nozzle was connected to the passenger side CCV? I can't imagine theyd just dump it outside, F**k the EPA style. lol? The vacuum from the turbo would drag it out of the vent and dump all the oil and crap into the turbo though so that would have been not very cashmoney of them either. Hmmm. I'll do more research, maybe that other vent line needs to be spliced to dump into the catchcan somehow.
2022 Q50 Luxe AWD
Discussion Starter · #10 ·
How hard was the install? And have you previously done work on cars?
I don't mind working on my own stuff, I've done oil and brakes, etc before on modern cars, and helped with more difficult stuff on older classic cars. I am mechanically inclined, and will get my hands dirty. However, that being said, this is a brand new car and a daily driver. I can't afford downtime. This, combined with the fact that the dealership near me has a service dept (and service manager) who are all gearheads and modders, moved me to have them do it. They said it won't affect warranty claims, at least not until I get it tuned or do crazy stuff to it that would cause obvious failures. They'll even do the HX and intercoolers/downpipes/Pure 2's when I'm ready. This is all very convenient and worth the extra price I might be paying since the closest AMS place is in NH somewhere and I can't get up there often. Also, I live in a large condo complex that doesn't really have anywhere convenient to do car work, plus they frown on it since they don't want oil stains everywhere. :[
2022 Q50 Luxe AWD
Discussion Starter · #11 ·
Basically, anything simple that just requires the hood open, and no fluids, I can probably do here. But anything that requires a lift or fluids getting on the ground, I'll have a dealer (or AMS service center) do it.
I may consider asking my dealership then too, my condo severely looks down mechanical work, but I figured this way be quick and easy enough it wouldn't matter.
2022 Q50 Luxe AWD
Discussion Starter · #13 ·
I know its only been a few days, but I'm tempted to open the can and see if anything is in it. How often do folks dump these generally? Do I need to do anything special like empty it more often in the winter, or take it apart and clean it once a year or something?
Spartanburg, SC 2016 RS Q50
I usually dump mine when I do my 5K oil change. If I get curious I may check it at around 2500miles. It's usually pretty low.
Reactions: Infinissan!
I dump mine when I do a 5K oil change also. I typically find about 20 ml of oil in the can.
If you live in a cold climate, you will definitely need to empty it often in the winter. It depends on your driving habits, but the can fills with condensation fairly quickly. I found I need to empty it about every 2-4 weeks depending on the weather and my driving patterns.
In the summer, as others have said you really only need to empty it likely every 5k miles.
Under boost there is no vacuum to the catch can, this type of system routes another line to the intake where the crankcase is vented so the catch can can get all the blow by under boost also. And since it took the hole the crankcase was vent, it's design vents the crank case to atmosphere. I understand how it works but think there could be a better way. But it does work. I'm just waiting for the perfect system before upgrading my basic catch can set up.
Font Parallel Art Pattern Symmetry
The valve covers are connected, so I see why people think this system is getting both sides, when in actuality even a basic catch can gets both, since they are connected with a hose. This system the op has is actually solving the problem of when boost builds and the pcv closes, there is no vacuum during that time, so it reroutes to the crank case vent, where there is a slight vacuum. Now because it takes where the crank case was venting, they give you a breather filter to take it's place. So now your crankcase pressure has somewhere to go. But by design the crankcase does better with a slight vacuum. Better for rings and well everything. I have a hard time explaining things, but this system isn't the best, your cutting into one vent to make another and leaving the crankcase with 0 pressure which is fine, (as long as it's not pressure) but it's better with a vacuum.
2022 Q50 Luxe AWD
Discussion Starter · #19 · (Edited)
Sorry if I seem to be a bit slow or tedious but I can be pedantic and nerdy when in datagather mode so plz bear with me, I am just trying to make sure I understand all this. So, my understanding of how this is supposed to be setup ( I attempted to verify this by looking at the routing of the hoses.) So from the factory, it seems the initial setup is as follows. There is a PCV valve on the drivers side as well as possibly a Crankcase vent. There is definitely a Crankcase vent on the passengers side. From stock, these seemed to be set up as follows:
1.) Passengers CCV on the valvetrain cover attached to passengers side turbo before compressor (via some nipple thingy)
2.) Drivers side PCV attached directly to manifold ( plz dump oil and garbage directly into my zoom zoomz hnnngh lol)
3.) Drivers side CCV = ???? is there one? no idea what the deal is here.
Post Catchcan install:
1.) Passengers CCV is no longer attached to turbo (yaaay??) Instead, the nipple whatever thingy is connected to the Output of the catchcan presumably to snag vacuum when boost is herpening. The CCV on the valvetrain cover now has a tiny air filter thingy on it that came with the ADD W1 kit so that's VTA i guess??
2.) Driver's side PCV is directly and firmly connected to the Input of the catchcan instead of the manifold as I imagine it would be. So now no moar 💩💩💩 being fed into my poor VR30.
3.) The manifold that was previously getting 💩💩 dumped in it is now the second Output for the catchcan, it is used to draw vacuum when at idle (or, at least, whenever the manifold is not pressurized and is at vacuum which I imagine is when no steppy on Go! Pedal)
So that all appears well and good. My concerns are as follows. Does the VTA on the passengers side valve cover present any issues? Is pressure being lost through this that shouldn't be? I ask because I have noticed a mild but obvious decrease in performance after having this thing for a week or so. It's not scientific as far as having numbers to back it up, but I trust my butt dyno and visual tracking of 0-60 times, with temperature and heatsoak accounted for. In other words even after a cold start or letting the IC pumps clear heatsoak from the HX on a hot day, I am not getting the yank from the car that Ive been getting since I bought it. Im getting about a 6.0 to6.2ish sec 0-60 where before it was probably 5.2 to 5.4 maybe (??) It seems like its pulling timing even at night when its not 85-90 out. I don't think it's bad gas, and I didn't change anything else. Repeated runs were done on flat surface allowing the air charge to cool off in between. All runs were done on Mobil 93 sourced from the same station I always use. WTF mang? LOL. Is there some thing Im supposed to do like an ECU or throttle relearn or something now that I have made these changes? There's a part of me that says "Dude chill out its just your imagination, or heatsoak" but the science part of me is like "yeahhhhh....."
1 - 20 of 23 Posts
