1 - 20 of 39 Posts
Tampa, FL
Circuit component Font Hardware programmer Cable Electrical wiring
Handwriting Laptop Computer Automotive design Font
Hood Automotive design Grey Bag Motor vehicle
St. Louis, MO
Kraken, what is your re-tune plan after your install?
Tampa, FL
Z1 Motorsports will get this dialed in once installed. I’ve already spoken to them about it and they’ve done all my tuning so far 👍
Reactions: jcb
2018 Q50 RS AWD. Black on Black on Black
Can you share pics of where you plummed the injectors to?
Tampa, FL
Will do. Haven't gotten there yet but def will. All sorts of random house stuff I have to get done so I've been moving at a slow pace.
I feel your pain! 🤣
2017 Q60 Luxe
I'm still trying to figure out where I'm going to place my injectors as well. It doesn't seem like much room between the IC and TB. I thought about just drilling and tapping the intake as I don't want them before the IC. Wonder if anyone has tried a TB spacer for injection?
RR
Links to build threads in sig of both locations I've used fwiw.
Tampa, FL
Discussion Starter · #10 · (Edited)
Mounted low level sensor and methanol line fitting from AEM tank to ProMeth tank. Mounted AEM pump on ProMeth tank. Ran wiring for pump and low level sensor to the trunk along with the methanol line.
Tire Wheel Bicycle Automotive tire Bicycle tire
Tire Wheel Vehicle Car Hood
Motor vehicle Hood Automotive lighting Automotive design Grille
Automotive tire Hood Car Black Motor vehicle
Audio equipment Gas Electronic device Electronic instrument Metal
Automotive lighting Circuit component Gas Auto part Rectangle
Telephone Gas Font Corded phone Telephony
Flash photography Wood Road surface Grey Asphalt
Allen, Texas
Your wire labeling and loom is an OCD masterwork - very nice! Looks like your install is shaping up nicely and similar placement / runs as mine (abet you are doing the safest and most complex route vs my JB4 WMI setup - Kudos!)
Reactions: Q50Wolf and Kraken
St. Louis, MO
There is room between the throttle body and the intercoolers. Way over-engineered fastening for the intercoolers. I just put one bolt back in each - would feel very comfortable with no bolts actually. Those are not going anywhere. Plus there is the benefit of the weight reduction!
Tampa, FL
Discussion Starter · #14 ·
That's a good little piece of info. I was looking at the couplers last night and you can't fit a human hair between the TB and IC. My current concern is how I'm going to get through the firewall. Once I make that happen the rest should be relatively easy.
@[email protected] - Thanks for the compliment. I take a lot of pride in my work and would like to create another solid resource for this install like @Ddnspider did.
Tampa, FL
Discussion Starter · #15 ·
Finally found a phenomenal wiring specialist to assist with this methanol install ❤ Have a bunch of pics and info to post. Been crazy busy.
Vehicle Car Hood Motor vehicle Automotive design
Tampa, FL
Discussion Starter · #17 · (Edited)
I'm in the same boat. The AEM hardware is nice however they don't include a TON of hardware required to properly install their kit. It really pisses me off as including everything required almost doubles the cost. They advertise there's built in safety features but you need to purchase additional parts to utilize them. The nozzles are 1/8" NPT and are an absolute bitch to find adapters for so you can connect them to the silicone couplers. Called up AEM and they told me to order them off the Snow Performance website 🤣 Then you're looking at $700.00+ for install by a reputable shop and they wouldn't do nearly as good a job as I have. You're looking at about $1,500.00 to have this kit installed on our cars.
EDIT: There's also an optional AEM WMI Solenoid $61.77 which is not required but looks to be a good safety feature that isn't included.
Reactions: Ddnspider
2017 Q60 Luxe
Completely agree and I look forward to the write up. My Burger Motorsports setup is nice but I needed the proper tank seal fitting for retrofitting to the oem washer fluid tank and a better nozzle injection solution. I went with TB spacers that I will drill and tap for the nozzles. But you doing a solid writeup should help others in the future and hopefully help people in ordering all the right parts from the get go to make it a weekend project.
Tampa, FL
Discussion Starter · #19 ·
The Snow Performance nozzle mount adapters just got here and they are MASSIVE. Back to the drawing board... What do you guys suggest I use to mount the nozzles to the silicone couplers in front of the TBs? @Ddnspider specified he's using a jam nut for this. However the AEM nozzles are 1/8" NPT units made out of aluminum. I can put a jam nut on but it'll never come off. It's a heck of a lot cheaper than these Snow Performance units for $67.00
Automotive tire Camera lens Camera accessory Flash photography Lens
Tire Automotive tire Camera accessory Rim Asphalt
Watch Clock Material property Watch accessory Automotive exterior
Guitar accessory Bumper Rectangle Font Gadget
Thank you for highlighting the real cost of these "bolt on kits". I got a bunch of flake for my "pieces together budget kit" option that was a total of $2xx including my failsafe lol.
1 - 20 of 39 Posts
