Yep. I bought the base because all I cared about was the 3.7 litter engine, the drive select, and the heated steering wheel. I knew I was going to upgrade the wheels and sound system myself anyway. I replaced the door 6.5 with alpine 6.5 components with tweeters. The doors have the mounting for the bose tweeters so it was pretty easy to modify the alpine brackets to fit the tweeter brackets in the door. The 6.5 alpines worked perfect with the stock mounting brackets for the most part, no rattling. I then tapped into the rear right door speaker wire for the sub signal and ran my signal wire for the amp of the left side of the vehicle through the fuse panel. Sounds way better than what was in there.
