First off, special thanks to Sid for fast processing and ease of transaction!
For those who are on the verge of buying and/or installing this, I'd say go for it! The heat exchanger is well-built.
Installation is pretty straightforward, I only followed AMS instructions posted here: https://www.amsperformance.com/wp-content/uploads/bsk-pdf-manager/Infiniti_Heat_exchanger_101.pdf
Instructions are very comprehensive and easy to follow. I installed it all by myself - no buddies, no nannies. Tools and materials I've used are:
- air compressor
- coolant refill/air purge (venturi) - $80 in amazon
- 10mm / 12mm / 13mm socket and extension
- Screwdriver and drill/driver and ratchet
- jack / jack stands
- wheel chocks
- needle-nose pliers
- plastic pry tools
- 1 gallon nissan longlife blue antifreeze (there's about 1.5 quarts left)
- shop towel
- torque wrench
- painter's tape
- gloves
- scissors
Total burden time: 6hrs (non-contiguous; includes photoshoot)
I'd like to note that venturi vacuum kit is awesome, there's almost no need to bleed. It filled up to about 75% on the reservoir when vacuum gauge reached 0. I only had to start and rev the engine a couple of times and it stabilized between the MAX and MIN lines. Drove ~200 miles thru my normal commute this week (traffic and several hard pulls) and no issues so far, though I haven't taken measurement and comparison of IATs yet.
If I were to mention any annoying part of the process, it'd be removing the RH headlight connector and trim panels that run along the fenders.
See pics attached and enjoy!
- air compressor
- wheel chocks
- plastic pry tools
- shop towel
- torque wrench
- painter's tape
- gloves
- scissors
