No KR PID or anything?I have the Os patch available! Hopefully it works like it should. I was never able to get the "the enhanced data stream" to work. i did not get any more channels available on the vcm scanner, even after a repoll. :/
I'll check your definition Monday, I'm not sure off the top of my head what's going on but I'll figure it outI have the Os patch available! Hopefully it works like it should. I was never able to get the "the enhanced data stream" to work. i did not get any more channels available on the vcm scanner, even after a repoll. :/
Can you check mine also or should I be good?I'll check your definition Monday, I'm not sure off the top of my head what's going on but I'll figure it out
I can always double check, no harm in doing so.Can you check mine also or should I be good?
Wow. Gotta love HPT support. Responses on a forum that doesn't belong to them AND on the fricken WEEKEND!I can always double check, no harm in doing so.
Oh but to answer your previous question about verification if the extended datagram is applied, run an infolog while connected to the car and see if Mode 0x23 is supported (it will tell you all the supported modes in the infolog). If it's supported then it correctly applied.
NO KR or anything. just tested The Os patch speed density and also nothing. seems like the patch is just not being applied.No KR PID or anything?
It doesn't appear that the patches are working for Isidoro1 at all...I can always double check, no harm in doing so.
Eric???I can always double check, no harm in doing so.
Am out on vacation, sorry the boondocks of wisconsin don't get very good service. Will investigate tomorrowEric???
Enjoy your vacation sir! We will be here! LOL!Am out on vacation, sorry the boondocks of wisconsin don't get very good service. Will investigate tomorrow
They have patches now for ED? Does that turn the software into hardware? Just asking.OK i think I found why your extra pids weren't showing up. The ED patch (keep your minds out of the gutter people) correctly applied, the software just doesn't know to scan for those parameters because your ID wasn't in a list we keep. I added it, if you update to latest (4.7.637 or later) it should reflect in the scanner.
As for why the SD patch isn't applying, that's stumping me, I'm looking at the definition right now and everything is added. Can you do me a favor and in VCM Editor hit CTRL + N (which should pop up navigator tree view) and then search for parameter 13357 in the text box after the patch has been applied to a file?
1 in 5 Q50 owners may benefit from this patch. Talk with your doctor to see if HP Tuners is right for you.They have patches now for ED? Does that turn the software into hardware? Just asking.
LMAOThey have patches now for ED? Does that turn the software into hardware? Just asking.
LMAO1 in 5 Q50 owners may benefit from this patch. Talk with your doctor to see if HP Tuners is right for you.
Yes, it shows up but editing the table does nothing to my fueling.OK i think I found why your extra pids weren't showing up. The ED patch (keep your minds out of the gutter people) correctly applied, the software just doesn't know to scan for those parameters because your ID wasn't in a list we keep. I added it, if you update to latest (4.7.637 or later) it should reflect in the scanner.
Eric, any reason why Isidoro1 sees no change in his fueling?OK i think I found why your extra pids weren't showing up. The ED patch (keep your minds out of the gutter people) correctly applied, the software just doesn't know to scan for those parameters because your ID wasn't in a list we keep. I added it, if you update to latest (4.7.637 or later) it should reflect in the scanner.
Can you send in a support ticket with a couple before/after logs and tunes with edits? There shouldn't be any reason why fueling doesn't changeYes, it shows up but editing the table does nothing to my fueling.
Okay i will do that, thank you. I already Ordered big turbosCan you send in a support ticket with a couple before/after logs and tunes with edits? There shouldn't be any reason why fueling doesn't change
