When I had help from my neighbor removing/installing the rear diff (for the Quaife LSD), I told him not to sneeze on either speed sensor, as Infiniti prices them like gold. I guess I wasn't that far off... smh
Yes I thought so as well. I had the senor replaced because I need my car. I'm seriously considering trading it in, so I didn't get the 60,000 mile AWD service. Since I paid my car off it seems everything is going wrong with it.A new wheel speed sensor is $282 online at InfinitiPartsDeal.com. Even with a frozen bolt, $1000 is pretty steep considering how simple replacing a rear wheel speed sensor is. I'm assuming the AWD service was simply changing transfer case fluid and for $443, that's excessive also. Gotta love Infiniti dealership repair costs.
I agree!That's insane. No reason it should have costed that much.
Yes I agree. I had no choice than to take it to the dealer. No one else had the machine to check for codes. (Don't know the name of it lol)A word I rarely use..."stealership". If I was quoted a grand for a wheel speed sensor repair, I would stand there and watch them, expecting at least 2.5 hours of sweat-inducing labor.
SMH!Aye was doing the rough math in my head and couldn't see how that would be more than a $700 including parts/labor. lol
For future reference, any auto parts store can do it. Also, cheap on Amazon you can order the tool yourself ab $25 so you can do it yourself (very easy just plug it in under the steerign wheel) Mine sits in my trunk, just in case I or a friend need it while out.Yes I agree. I had no choice than to take it to the dealer. No one else had the machine to check for codes. (Don't know the name of it lol)
Wow thanks so much.For future reference, any auto parts store can do it. Also, cheap on Amazon you can order the tool yourself ab $25 so you can do it yourself (very easy just plug it in under the steerign wheel) Mine sits in my trunk, just in case I or a friend need it while out.![]()
Amazon.com: ANCEL AD310 Classic Enhanced Universal OBD II Scanner Car Engine Fault Code Reader CAN Diagnostic Scan Tool-Black : Automotive
Buy ANCEL AD310 Classic Enhanced Universal OBD II Scanner Car Engine Fault Code Reader CAN Diagnostic Scan Tool-Black: Code Readers & Scan Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Just to be clear most of the cheaper Scan tools DO NOT allow you to check codes for TPMS or wheel speed sensors. You usually need to throw down $150-$300 for ones that can actually scan the entire system and perform basic functions.For future reference, any auto parts store can do it. Also, cheap on Amazon you can order the tool yourself ab $25 so you can do it yourself (very easy just plug it in under the steerign wheel) Mine sits in my trunk, just in case I or a friend need it while out.
Really? Wouldn't it just come up as a standard code, or at least just give you the code# to check?Just to be clear most of the cheaper Scan tools DO NOT allow you to check codes for TPMS or wheel speed sensors. You usually need to throw down $150-$300 for ones that can actually scan the entire system and perform basic functions.
That said still handy to have on hand if a code/warning comes up on the dash and you aren't sure why.
Nah its one of the area's where most scan tools cut corners and you don't get the feature.Really? Wouldn't it just come up as a standard code, or at least just give you the code# to check?
Learn something new everyday, might look into grabbing one. Being the "diagnostic fee" is what $180? Could pay for itself with a use or two.Nah its one of the area's where most scan tools cut corners and you don't get the feature.
From a dealer? Yeah like $100-$200 diagnostic charge pretty typical, honestly its pretty easy to justify going with a higher end scan tool if you do your own car work.Learn something new everyday, might look into grabbing one. Being the "diagnostic fee" is what $180? Could pay for itself with a use or two.
I don't think everything is going wrong with it. AWD service is recommended maintenance. It usually entails replacing both front and rear differential fluid and the transfer case fluid. Not sure why folks on here are assuming it is just the transfer case.Yes I thought so as well. I had the senor replaced because I need my car. I'm seriously considering trading it in, so I didn't get the 60,000 mile AWD service. Since I paid my car off it seems everything is going wrong with it.
Hard to say. It could be a temporary fault. I would suggest if it happens again, scan the car for DTCs before shutting off the engine and see if you have any. Cyclling the ignition can clear temporary DTCs.I got the AWD Warning last night when I started my car. I drove to the store and then back home and it was on the whole time (normal weather). This morning there was nothing at all, is it possible a speed sensor is about to go bad/is bad?
OBDII ELM327 w/ OBD Fusion app >>>>>> scan toolsJust to be clear most of the cheaper Scan tools DO NOT allow you to check codes for TPMS or wheel speed sensors. You usually need to throw down $150-$300 for ones that can actually scan the entire system and perform basic functions.
Yeah, he'll need a higher level scanner to do decent troubleshooting.OBDII ELM327 w/ OBD Fusion app >>>>>> scan tools
