That's usually what causes his problem...hopefully. It could also be the AWD Control Unit or the ABS Actuator and Electric Control Unit, which are spendy.I had this issue and took it to the dealership where they found that it was a speed sensor that went bad. It was replaced under warranty and haven’t had an issue since.
I just had the same error pop up at 32k .Today this awd error warning popped up on my 2015 q50 premium, has this ever happened to anyone? If so was it expensive to get it fixed? View attachment 91618
Correction awd solenoid.I just had the same error pop up at 32k .
I took it to a local garage and they said it was a transmission solenoid. code and to take it to the dealer.
Any guidance
I took It to the dealer and they said it was a speed sensor. They wanted the 365 for the part.Correction awd solenoid.
Where is this located?
It was the right rear abs speed sensor, very typical I heard from the service managerI took It to the dealer and they said it was a speed sensor. They wanted the 365 for the part.
It looks like 15 min worth of work. Does anyone know the part number?
I was looking at infinit parts deal they have it for $204 OEM pretty impossible to get it aftermarket
No sport brakesWith or without sport brakes?
Completed the installation of the abs speed sensor.Hopefully, it does not come down to luck. LOL
The dealer quoted the part at $365 with tax.
I saw them at other dealers for $265 all were oem
Doing back brakes as well at 32 k , I am second owner, It was from NYC
Front brakes were done at 18 k with rotors, he must have been hard on them for such low mileage
Did you end up fixing it and what was it I just got it yesterdayToday this awd error warning popped up on my 2015 q50 premium, has this ever happened to anyone? If so was it expensive to get it fixed? View attachment 91618
