Should you be interested in a BlendMount, you will need:
BlendMount BBE-2012 and MACRO MirrorTap MT-3009
You can also use coupon code "friend" if you buy direct. Note- I am not a BlendMount employee, affiliate, etc.
It wasn't an easy install, but not hard either. It just takes some patience when working in the tight spaces. You will have to remove the sleeve that covers the cable that runs from the mirror to the camera. It pops off very easily. This may only be on cars equipped with the tech package.
Installing the power tap was the easiest part. Just make sure you get the mirror tap with .04 " Molex blades if you have the advanced technology package. If you don't have the tech package, then the mirror tap with .05 " Molex blades might be the right solution.
The trickiest part is getting the angles right so the detector comes out under the mirror exactly where you want it.
The guys at Blendmount were amazing. I ordered the blendmount and the mirror tap from Amazon. Turns out it was coming from two different vendors. The blendmount was coming from a reseller, the mirror tap from blendmount themselves. I got an email from BlendMount asking me if I had also purchased a mount that may have gone through an Amazon reseller. I sent them pictures, and they indicated I ordered the wrong mount. They sent me an adapter that would replace the part of the mount that I ordered that wouldn't have worked as well. It was a subtle difference, but you should make sure to get the right one. They also sent me both the .05 inch and .04 inch Molex Connectors. I will post proper part numbers later.
