We've all learned that the break-in period for the gasser is 1200 miles. The hybrid is a different animal, allowing owners to run in EV mode - using the electric motor only for propulsion. Hybrid owners can see the number of miles they've amassed by viewing the EV Odometer in the middle display. Since the gasoline engine was off while EV mode was engaged, I will be subtracting the value in the EV Odometer from my total mileage to arrive at the number of miles driven while the gas engine was running, and I'll wait until this number is 1200 or more before I exceed 4000 rpm on the tachometer.
Interesting, eh? This was not mentioned in the manual...
What do you think?
However, with running on the EV motor requires a lot of shut off and start up of the engine, which is a lot harder on the engine than running for hours at say highway speed. So the net of it I believe averagely out the starts and stops the engine I don;t think you should subtract the EV miles. 1200 would be a good average for both.
Having said that, Nissan breaks in engines at the factory by running them at redline for 7-8 minutes, then change the oil. When a Q50 rolls off the lot (much like GT-R) or others at Tochigi plant, they take it on their own test track to break-in the suspension, brakes, etc.
My break-in for many VQ engines has been:
first 200-300 miles city driving keeping it under 3500 rpm
200 or so miles highway driving
then followed by a nice spirited driving session or track - redline, brakes, suspension, etc is all broken in at this point. everything is pushed to it's heating limits.
Then an immedite oil change.
