1 - 1 of 1 Posts
Banned
Located in
Bully Dog Triple Dog GT Gas tuner
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
I am adding a money back guarantee to this auction by request of a prospective customer to prove that this unit has been returned to stock and ready to go. I did look for a page to confirm this when I took pictures for auction and was not able to find the page. Your satisfaction is my number one goal. The last thing I did before trading in my pathfinder was to flash ecu back to stock and uninstalling this unit. I would have never bothered to uninstalling unit if I didn't flash stock program back because that would make this useless. If you look at first picture you can see the option to change vehicle at top. I believe that this option is blocked when unit is not stock. Bully Dog Triple Dog GT Gas tuner (40415) used in very good condition, Fully functional, showing minor scuffs from normal wear and tear. Tuner has been returned to stock and is ready to select vehicle. Includes user manual, true RAM mount (not the cheap vehicle mount that comes with new units), It is setup already for a easy install with fuse tap already installed on vehicle power connector. Wiring it is as simple as finding a switched power circuit in fuse box removing fuse, installing fuse tap and putting original fuse in fuse tap "assuming your vehicle uses same size fuse as the fuse tap, and routing ODB cable to mounting location on dash and tucking wire away to your liking. Tuner was installed on a 2006 Nissan Pathfinder and it was a remarkable addition to the vehicle. It allowed reading of engine trouble codes, monitoring all the supported sensors, keep track of MPG in real time, driving coach, reseting Engine Trouble Codes, advancing the timing and installing the performance tunes. The vehicle had WAY more power and get up and go than stock! I couldn't live without it once I tried it! It improved fuel economy as well as long as you can keep your foot off of the gas pedal. NOTE: The supported features vary by make and model of vehicle unit is installed on see manufacturers website for details. When flashing programs it is critical that you have a fully charged battery because if it dies in the middle of the flash that complicates matters. IMPORTANT! to the winner of the auction, PREPARE UNIT FOR YOUR VEHICLE FIRST! . This will make sense once you receive and power up unit. Download and install the bully dog update tool from bully dog website. You MUST! power up unit with sync cable attached to Windows computer, hit second button down on left side to access menus. You then hit menu button, then up cursor to display change vehicle option menu, select your vehicle here. This option is hidden when you first hit menu button until you move up one space on display, then follow onscreen instructions to download the bully dog update for your vehicle to the latest version from bully dog server before installing the unit or flashing your vehicle. Then once all this is completed install in your vehicle and flash away! Auction includes user manual, sync cable, ODB connector, sd card, Bully Dog Unit, Power wire with fuse tap, hdmi cable to hook from Bully Dog unit to ODB connector, and upgraded RAM mount, I do not have original packaging. You can check vehicle compatibility on supported vehicle list below. SUPPORTED VEHICLES: Cadillac Escalade 5.3L V8 2002-2005 6.0L V8 2002-2006 6.2L V8 2007-2014 Chevy/GMC Avalanche 5.3L V8 2002-2014 6.0L V8 2007-2014 8.1L V8 2002-2006 Camaro 6.2L V8 2010-2013 Cruze 1.4L T 2011-2014 Express/Savana 4.8L V8 2003-2014 5.3L V8 2003-2014 6.0L V8 2003-2014 8.1L V8 2001-2003 Sierra/Silverado 4.8L V8 1999-2013 5.3L V8 1999-2014 6.0L V8 1999-2014 6.2L V8 2007-2014 8.1L V8 2001-2007 Sonic 1.4L T 2012-2014 Yukon XL/Suburban 5.3L V8 2000-2014 6.0L V8 2000-2014 6.2L V8 2007-2014 8.1L V8 2001-2006 Yukon/Tahoe 4.8L V8 2000-2014 5.3L V8 2000-2014 6.2L V8 2007-2014 Chrysler 300C 5.7L V8 HEMI 2006-2010 6.1L V8 HEMI 2006-2010 Aspen 4.7L V8 2008-2009 5.7L V8 HEMI 2007-2009 Dodge Challanger 5.7L V8 HEMI 2009-2010 6.1L V8 HEMI 2008-2010 Charger 5.7L V8 HEMI 2006-2010 6.1L V8 HEMI 2008-2010 Dakota 4.7L V8 2008-2010 Durango 4.7L V8 2008-2009 5.7L V8 HEMI 2004-2009 Magnum 5.7L V8 HEMI 2006-2008 6.1L V8 HEMI 2006-2008 Ram 1500 4.7L V8 2008-2010 5.7L V8 HEMI 2003-2010 Ram 2500-3500 5.7L V8 HEMI 2003-2010 Ford E-Series 150-350 4.6L V8 2005-2008 5.4L V8 2005-2008 6.8L V10 2005-2008 Excursion 5.4L V8 2005 6.8L V10 2005 Expedition 5.4L V8 2005-2010 Explorer 4.6L V8 2005-2010 F-150 3.5L ECO BOOST 2011-2013 4.6L V8 2005-2010 5.0L V8 2011-2014 5.4L V8 2005-2010 6.2L V8 2011-2013 F250-550 5.4L V8 2005-2010 6.2L V8 2011-2014 6.8L V10 2005-2010 Mustang 4.0L V6 2005-2010 4.6L V8 2005-2010 Raptor 6.2L V8 2010-2013 Infinity EX 35/EX 37 3.5L 2008-2012 3.7L 2012-2014 FX 35/FX 45/FX 37 3.5L 2005-2012 3.7L 2012-2014 4.5L 2005-2008 G 35/G 37 3.5L 2005-2009 3.7L 2009-2014 JX 35 3.5L 2012-2014 M 35/M 37/M 45/M 56 3.5L 2006-2010 3.7L 2011-2014 4.5L 2005-2014 5.6L V8 2011-2014 Q50 3.7L 2013-2014 Q60 3.7L 2013-2014 QX50 3.7L 2013-2014 QX56 5.6L V8 2005-2014 QX60 3.5L 2013-2014 QX70 3.7L 2013-2014 Jeep Commander 4.7L V8 2008-2009 5.7L V8 HEMI 2006-2010 Grand Cherokee 4.7L V8 2008-2009 5.7L V8 HEMI 2006-2010 6.1L V8 HEMI 2006-2010 JK Wrangler 3.8L 2007-2010 Lincoln Mark LT 5.0L V8 2011 5.4L V8 2005-2010 Nissan 350 Z/370 Z 3.5L 2005-2009 3.7L 2009-2013 Altima 2.5L I4 2005-2014 3.5L 2005-2014 Armada 5.6L V8 2005-2014 Cube 1.6L I4 2009-2011 1.8L I4 2009-2014 Frontier 2.5L I4 2005-2014 4.0L V6 2005-2014 Maxima 3.5L 2005-2014 Murano 3.5L 2005-2014 NV2500/3500 4.0L V6 2012-2014 5.6L V6 2012-2014 Pathfinder 3.5L 2012-2014 4.0L V6 2005-2014 5.6L V8 2008-2014 Quest 3.5L 2005-2014 Rogue 2.5L I4 2008-2014 Sentra 1.8L I4 2013-2014 2.0L I4 2007-2014 2.5L I4 2007-2014 Titan 5.6L V8 2005-2014 Versa 1.6L I4 2007-2014 1.8L I4 2007-2014 Xterra 4.0L V6 2005-2014
1 - 1 of 1 Posts
