1 - 4 of 4 Posts
So after receiving trouble codes after my tune on VP X98 racing fuel, I received cylinder 1 misfire and random/multiple cylinder misfire. So I changed all my fuel injectors, and now reviewing codes cylinder 1 misfire, cylinder 2 misfire, random/multiple cylinder misfire, and fuel rail/system pressure too low. What gives?
Product Font Screenshot Rectangle Parallel
Misfires could be your spark plugs. Also, are they larger injectors, or OEM sized? Low fuel pressure is likely the fuel pump.
Did you upgrade your fuel pump? I'm thinking maybe your fuel pump isn't keeping up regardless of the injectors you are using.
With all those codes, I would say you have an electrical problem. TPMS, airbags, and misfires? Could be the battery. Have the battery and Alt load tested.
1 - 4 of 4 Posts
