1 - 6 of 6 Posts
2016 Redsport awd | Stillen catback exhaust | ams intakes | ams downpipes | Mishimoto HE | Hks Bov
I’m currently running my base map with seb from specialty z right now..my logs look good except my charge air coolant temperature is not moving at all. Its Been reading 70 or 75 from my cold start and and does not change through heavy load ( 2500 Rpm to redline ) ....I’ve done 3-4 runs one after another and that’s the only reading that does not change. Seb recommended that I burp the coolant system to get the air bubbles out which I’ve done and still no change. could It be possible that the air charge coolant temperature sensor has gone bad ? I’ve checked and it’s connected properly .
I just posted something similar mine seems bad as well. Seems to be a common failure.
Reactions: MrDemon400rs16
Yea I’m just seeing your post now...I just ordered an “oem like “ sensor from z1 motorports.....I’m gonna replace the old with that and see if that works...This is not my first sensor that has gone bad and I’m just hitting 40,000 miles
I wouldn't go so far to say it is common. Sensors can and do fail though.
It happens. Enthusiast POV has a video on how to replace it - see below.
2017 Infiniti Q50 Premium 3.0t AWD
anyone have a link to where to buy this sensor? I cant find it anywhere
Edit: Nevermind, I found it through a dealership. $33 for the part.
1 - 6 of 6 Posts
