Yep! the error code is stored, so they should be able to retrieve the data. Was the gas cap on tight??
Yep! the error code is stored, so they should be able to retrieve the data. Was the gas cap on tight??Was driving long distance for the first time yesterday from Dallas to Austin for the Formula 1. Half way there, check engine light came on. And it was on all the way back. This morning, started the car, it was gone.
Anybody seen this? Do you think the service guys can find the problem if the light is not on now?
Doubtful. This same thing happened to mine, except mine stayed on. Took it to dealer, and there were no codes stored. They just used the consult to turn the light off.............Yep! the error code is stored, so they should be able to retrieve the data. Was the gas cap on tight??
