Post Pictures of your Bronzed Chestnut (CAN) Infiniti Q50
Nice. Maybe we'll see some customers asking to have their chestnuts bronzed.
Holy orange peel! What can be done to smooth it out? Can a detailer fix the orange peel?
Nope. Orange peel happens as a result of the paint being applied unevenly beneath the clear coat. Just about every car has some degree of orange peel these days due to painting techniques and other variables. The clear coat is the top layer which is generally glassy smooth, or will be once you clay bar it and wax/polish it.Holy orange peel! What can be done to smooth it out? Can a detailer fix the orange peel?
Thank you for the excellent answer!Nope. Orange peel happens as a result of the paint being applied unevenly beneath the clear coat. Just about every car has some degree of orange peel these days due to painting techniques and other variables. The clear coat is the top layer which is generally glassy smooth, or will be once you clay bar it and wax/polish it.
Alot of things cause orange peel and the urethane-based paints everyone uses now is the main culprit. Urethane-based paints are nice for the fact that they stay flexible and thus don't chip on impact as easily, and when sprayed on plastics, tend to deform with the plastic and recover nicely rather than bust off in big chunks. Most plastics use flexible urethane coatings while harder compounds may be used on metal parts.
This is a pretty ugly example of it though, and I hope production models don't look that bad up close.
These are MUCH better photos than the previous. I thought it would be an ugly bronze color not this nice chestnut brown. I like this now.
