I think I answered your questions in a different thread.. but again, I replaced my GOOD OEM turbos (no problems with them) @ 30K miles, with the Pure Stage 2 turbos, for higher performance (HP). Along with the supporting fuel modifications. Takes fuel to make power.
I don't get why many of us did not have turbo problems and yours both went bad at 5000 miles. Maybe a batch was built with poor quality seals. The failures are not mechanical as I understand, but leaking oil from bad seals. (Correct me if I'm mistaken).
The Pure Stage 2 I would suspect would be more maliciously built and may not use the OEM seals.
Be advised the Pure turbos have a VERY different power band. They make their power 4500-7000 RPM. The OEM make more power at lower RPM, but fall off at 5500 RPM. If tuned the OEM turbos have a big torque hump 2500-3500 RPM level off and start to drop at 5500.
20 PSI seems to be the top of the OEM turbo efficiency range. Stillen has a chart showing this. @ 21-22 psi no more power, just tons of heat. While the Pure Stage 2 turbos make good power up to 23 PSI.
This is with pump 93 octane gas.
I don't know of any aftermarket turbos that have the same characteristics as the OEM turbos. If your only looking for increased reliability. Blowoff valves do nothing but help your turbos. If tuned you should get them.
