This is really frustrating
This is the first time I have read about turbo seal failure reason.
I can not recall Evo or Wrx/STI owners having this problem.
Oh yeah, I had an MR2 Turbo for a while. Never heard of issues there.
Sure a turbo can fail here and there, but not because it has an Achilles heel.
I'm not familiar enough with the Evo or WRX/STI but I recall turbo failures
being pretty rampant in the 90s, that said it's a little odd to compare two
totally different engines and likely model of turbos.
There is always going to be production issues as things are changed out and upgrade.
But I would agree that it
shouldn't be this common of an issue this late into the life-cycle
of the engine.
Based on my reading the VR30 runs a custom spec MGT1446Z Garrett turbo which is related
to the turbo found in VW 1.8 TFSI which arrived around 2012 but its hard to say if these turbo
failures are the result of over-heating or poor turbo design.
I'm leaning towards turbo design more so than over-heating (although it could be both),
a larger stock XE would have been a pretty easy fix to push out from Infiniti if
it was just a heat issue.
