1 - 11 of 11 Posts
'17 SS
Hey guys,
Just came back from an oil change on my 2017 Q50S. I got quoted $510 for a coolant leak from the thermostat multi-way control valve housing.
I have a few questions:
Is this common for the VR30?
Can I fix it myself?
Does anyone know the fix for this??
I attached photos of the issue, as well as the quote. Please let me know!
95218
95217
95219
95220
First off, that's not the thermostat in the pictures you posted. Here's where the thermostat is (#1):
95227
Your pictures are of the multi-way control valve (#1), however it has been referred to as a thermostat in parts catalogs also.
95235
A replacement multi-way control valve goes for $335 on discountinfinitiparts.com plus labor. If it just needs to be resealed, then the cost should be less.
To remove the control valve, you'll have to disconnect a half dozen hoses, remove the drive belt, drain engine coolant, remove the reservoir tank, and disconnect a couple of harness connectors.
Not knowing your skill level as a shade tree mechanic, I can't say if you can fix it or not if removal is necessary. Resealing it would be a lot easier if it doesn't have to be removed from the engine to access sealing any leaks.
Reactions: rpiotro
'17 SS
Thanks for the info, I can do it myself, but that seems like alot of time and effort, both of which I do not really have. If its just o-rings or resealing, would $510 still be fair?
Not knowing what all has to be done to seal the leak, it's hard to say. I would guess it depends on which gaskets need to be replaced and ease of access.
Any reason you wouldn't get the work done by Infinit? Should be covered under warranty.
^This, unless the car is over the 70k mile powertrain warranty mileage limit.
'17 SS
You know, I did not even think about that. Thanks!
'17 SS
Discussion Starter · #8 ·
I am sitting at 34662, I should be okay. I will give them a call. Thanks for the advice
Odd that the dealership would give an estimate for the repair but not mention that it was covered under warranty.
Reactions: rpiotro
If I wanted to reseal mine couldn’t I unscrew the cap and do so it would I have to drain? Could I use rtv
1 - 11 of 11 Posts
