1 - 9 of 9 Posts
*title
Finally after 2 months I checked in the trunk if I have all the tools required to change tire in case I need to and what do I find? I don't have a freaking jack in the back. All I have is tool to unscrew the bolts and nothing else. Did the dealer forget to put it there or does the Q hybrid doesn't come with one?
*title
It doesn't come with one.
Nope. No spare or jack. Hopefully, my run flats won't fail me if I need them.
**** you run flats taking our beloved tools away
Reactions: andrew and EdB
It's funny, I have had 8 Infinit's and never used the jack ever so with RFT on Q50, I doubt I will need one, used AAA once for flat tire on my g35 coupe in last 10 years.
*title
Just get yourself an inexpensive air pump (12 volt). That will take care of any slow leaks, until you get the tire repaired. I haven't had to change a tire in 6 years.
*2 days later cvipgo needs a jack lmao
Jk
Plews 16-200 12V Electric Hydraulic Automatic Lift Jack - 1.1 Ton Lift Capacity : Amazon.com : Automotive
btw: I have AAA and an electric jack in case:p+ Infiniti service
here's info on electric jack- its great, in case
1 - 9 of 9 Posts
