Just came across this video for disabling the ASC on MY2020+ Q50s & Q60s w/Bose Audio:
I figured there was a way to get into the newer model's diagnostic menu. It just didn't go away.Just came across this video for disabling the ASC on MY2020+ Q50s & Q60s w/Bose Audio:
Where in the menu, also can you change the duty cycle on a base modelI figured there was a way to get into the newer model's diagnostic menu. It just didn't go away.
Excellent find!
I wouldn't touch that. I bet that toggle is in there strictly for testing / troubleshooting. Not for operating the vehicle normally.In that menu there is a toggle for duty cycle of the heat exchanger pumps. I believe you can set them to 100% on vs scaling on demand. Any thoughts there?
If you don't have the Bose system, the diagnostic menu won't have the ability to turn ASE and/or ANC on or off. The base audio system requires disabling the Active Noise Control Unit, which can be done by disconnecting it but you lose ANC in addition to the engine sound the ASE provides.I have a Q50 luxe 2022, have accessed the adjustment menu but the ASC/ANC option was not available… did anyone experience the same thing and if so is their any other solution to disable to ASC?
That option is on all pre-2020 Q50s as well. A large number of us use our cars with that option turned off right now.I wouldn't touch that. I bet that toggle is in there strictly for testing / troubleshooting. Not for operating the vehicle normally.
Confused. You're implying that you turn off the duty cycle on your heat exchanger pump(s)? I'm not sure you read the context of my message?That option is on all pre-2020 Q50s as well. A large number of us use our cars with that option turned off right now.
Oh my bad, thought you were referring to the ANC ASC functions.Confused. You're implying that you turn off the duty cycle on your heat exchanger pump(s)? I'm not sure you read the context of my message?
