This is next for me along with the Z1 undershroud. Great insurance and looks clean.
I COULD google this, but I’ll just ask: was the oil pan baffled?
I bought the shroud first. Are we sure dropbear pan and Z1 Armor will fit together?This is next for me along with the Z1 undershroud. Great insurance and looks clean.
Chassis bracing by soul function. they have maybe one brace that fits the AWD, and the rest are for the RWD.The tealish blue, what type of braces are those?
Perfect!I have the TBW Performance Skid Plate for my '17 Q60S AWD:
Aluminum Under Tray for AWD 2014-2020 Infiniti Q50 & 2016-2020 Q60 (V37) BLACK
The only fit issue I found was one of the bolts that retains the oil plug access door cannot be used as-is because it will contact the Dropbear oil pan when it is threaded-in. You'll need to find a shorter bolt that just engages the nut plate. I found two shorter bolts to install, so that future techs couldn't screw up the install.
Good call. I'm really disappointed with the OEM lack of oil pickup baffling. Rolling with the shorter dipstick helps, but if you do anything outside of daily drive your Q, the installation of this Dropbear Oil Pan is a no brainer for reducing chances of oil starvation under 'g' load.#3 on DropBear’s list 😂
Are they worth adding to the shopping list? Or are they slight placebo?Soul Function chassis braces
@PerfectWhiteQ50S said it well, it depends on what YOU value. For me, chassis bracing is a no brainer. Because I auto cross my car, I’m looking everywhere I can to increase my Qs rigidity so I can better utilize its power.Are they worth adding to the shopping list? Or are they slight placebo?
DittoA Shelby GT350R?!?! I hate you.
Pics of the Shelby or it didn't happen.I work a ton to have that luxury. And it is a fun car. But the Q is something more tame and subtle that makes driving fun in a different way. I mean truth be told I would have a ton of cars if I had the means to do so. But for now I will drive my work truck more in a month than either of the other 2 in 3 months time.
