How accurate is the pressure measurement? +/- 1 to 2 pounds?
Based only on my air pressure gauge, I'd guess +/- 1 PSI but that's assuming my pressure gauge is exact and it may be off itself.How accurate is the pressure measurement? +/- 1 to 2 pounds?
I know that you know that I don't use N2. There's none around here and I'd only use it if it's free anyway.I can't believe you would bleed off 5 pounds of invaluable pure nitrogen for this experiment.
N2 is overrated. 😀Based only on my air pressure gauge, I'd guess +/- 1 PSI but that's assuming my pressure gauge is exact and it may be off itself.
Currently $120. That's $35 without the Ryobi charger and 18 VDC battery pack though. Throw those in and it's essentially the same price.Hey AV if I remember correctly you said $100-125 on Amazon, I still use my Ryobi 18v, that I've had for two years, not sure how close the +/- is, but for $35 at Home Depot.
Your right there, with myself, I have three 40v battery packs, two chargers for them, three 18v batteries, and two chargers for them, so I just keep adding the tools.Currently $120. That's $35 without the Ryobi charger and 18 VDC battery pack though. Throw those in and it's essentially the same price.
I've got four 80 VDC battery packs (2 Ah to 7 Ah) and two chargers for my backpack blower and blade edger. I've also got two 40 VDC battery packs (2 Ah) for my hedge trimmer and pole hedge trimmer. I have an electric-start Honda gas mower though.Your right there, with myself, I have three 40v battery packs, two chargers for them, three 18v batteries, and two chargers for them, so I just keep adding the tools.
I've done away with gas equipment, both snow and grass equipment are now battery operated. My lot is small, that I can cut the grass twice with the same charge.I've got four 80 VDC battery packs (2 Ah to 7 Ah) and two chargers for my backpack blower and blade edger. I've also got two 40 VDC battery packs (2 Ah) for my hedge trimmer and pole hedge trimmer. I have an electric-start Honda gas mower though.
I just retired my gas edger, so the only things remaining are my pressure washer and mower. Electric pressure washers are too weak and my lawn is too big for an electric mower and I need more torque to cut tall grass.I've done away with gas equipment, both snow and grass equipment are now battery operated. My lot is small, that I can cut the grass twice with the same charge.
Thanks for the heads-up and thanks @Avedis53 for the overview. I placed an order today as well for $90.A $30 coupon now available for $89 just ordered one
From where I might ask?Thanks for the heads-up and thanks @Avedis53 for the overview. I placed an order today as well for $90.
I already have a combo Slime injector/compressor but if I ever need to use it, I'll only pump in the Slime with it and switch to the Fanttik to inflate the tire.I’m thinking this plus the tire inflator would be a good combo
Amazon.com: Slime 60187 Thru-Core Emergency Tire Sealant - 18 oz for Emergencies, Flat Tire Puncture Repair Sealant, Emergency Repair for Highway Vehicles, Made for Trucks, SUVs and Vans : Automotive
Buy Slime 60187 Thru-Core Emergency Tire Sealant - 18 oz for Emergencies, Flat Tire Puncture Repair Sealant, Emergency Repair for Highway Vehicles, Made for Trucks, SUVs and Vans: Automotive - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I should send mine back and buy the yellow striped one but I'm too lazy.Amazon, coupon was an option when ordering
