Anyone have flickering on reverse on the screen?
I'll post a video later when I get home.
Id agree, specially when I jump in my G37 and fire up the engine and put it in reverse, the backup camera is ready in 2 seconds, with guidelines in place.It takes 90 sec for them to turn on. That's ok for specs at this time per my dealer Technician. I'm not in the habit of waiting 90 sec to back up. Annoying.
by no means is that normal/acceptable. my G used to switch into the camera right away.It takes 90 sec for them to turn on. That's ok for specs at this time per my dealer Technician. I'm not in the habit of waiting 90 sec to back up. Annoying.
It would suck if you have to wait a whole after you start it up, always best to have it ready to go when you are. **** that lag!Id agree, specially when I jump in my G37 and fire up the engine and put it in reverse, the backup camera is ready in 2 seconds, with guidelines in place.
90% of the time its the cameraAnyone have flickering on reverse on the screen?
There you have it, from the tech himself90% of the time its the camera
10% its a loose connection or a kink in the line somewhere
ive seen it happen to G's and M's also, pretty rare though..
Yes. And since I have the tech package it also intervenes & applies emergency brakes should I get too close to an object. My rear camera loads almost instantaneously after starting my car; no need to wait for InTouch to load.When backing up and close to an object does it beep. My old infiniti did. Does this one ??? Thanks.
