1 - 10 of 10 Posts
I am picking up my Q50S Hybrid AWD today and giving up my 2007 G35x.
I have the original cloth floor mats along with the rubber all weather floor mats. Both are OEM on the G35x.
If I had to choose one that will fit the new Q50S or keep to resell, which one should I keep?
Also, the dealer is only requesting 1 key. Does the second key that I never use worth anything?
Floor mats from g won't fit q but you try after you get th Q. Dealer should provide you two key fobs.
Thanks for reply. I meant for the G35 I am trading in, the dealer only requires me to hand in 1 key fob of mine. Should I keep the other one or should I just hand it in as well? Is there any resale value in it?
I did the exact thing traded in my '07 for a Q50S. I'd keep the all weather even though I had weathertechs from the '07 that fit quite well (even in the trunk) in all except for the driver side where there is a small gap by the door.
I had to give up all 3 keys I had, but the second key is worth some cash not much. The FOB can get reprogrammed but you have to get a new blade which can be ordered through ebay for quite cheap but they do not have the transmitter in them so you can't start the vehicle if the battery runs out.
Give them both keys. You can't get much for it and the next owner will be happy.
Keep the all weather mats. If nothing else, you could trim them with a shears to fit the Q and use for a little while until you decide what to buy for it.
Discussion Starter · #8 ·
Thanks guys! Much appreciate the advice!
Also, picking the car up in an hour or so. Any advice on what to keep an eye on? What to look for?
1 - 10 of 10 Posts
