1 - 7 of 7 Posts
Hey guys, Recently bought my q50s used. I have been fixing up a few things. I noticed my front bumper hangs lowes and is creating a gap by the hood. Is there anyway i could fix this or do i need a new bumper?
Wheel Tire Vehicle Vehicle registration plate Grille
Car Vehicle Land vehicle Plant Grille
Spartanburg, SC 2016 RS Q50
I would loosen and re-adjust the bumper to see if you can get it set right. If you didn't hit something then I'd assume the previous owner or dealers may have bumped something or it may have been removed before. I'd definitely investigate to see if there happened to be an upgraded heat exchanger hidden behind the bumper.
2021 Q50 Signature Edition -- I know, shocking given my Username
The hood may need adjustment as well. There's definitely been some work there, because the color match on the front bumper is a bit off.
It looks that way because of the angle the hood is hanging at. IRL it looks like the same color. thank you guys i will try to readjust it this week end with my dad see if that works.
1 - 7 of 7 Posts
