Should mention it is a 2016 q50 3.0T
What happens if you don't go in that order - will the vault not open? I could see using some order for a torque sequence, but for removal...just zip those things off!Your nomenclature confused me. Do you mean the front timing chain case?
I'm assuming you set #1 cylinder at TDC of it's compression stroke before pulling the crankshaft pulley?
