fuel trim short 125 (BANK 1&2) AFR 20
467 Views 8 Replies 5 Participants Last post by  MNV
Hi all! I need help! A year ago I ran into a problem fuel trim short 125 (BANK 1&2) AFR 20
I changed everything that is possible, but unfortunately it does not help! Some kind of problem with the fuel.
I changed the entire fuel system (nozzles, injection pump, low pressure pump), I cleaned the line itself.
Checked the intake system for leaks.
Changed lambdas and oxygen sensors.
I checked the flywheel, crankshaft and camshaft daotchik.
Rolled everything back to factory firmware.
Unfortunately there is no error DTC code!
In general, if anyone encountered a similar problem, tell me what to do!
1 - 9 of 9 Posts
Is there anyway you can pull the DTC code from the ECU? If you can do that, I think we'd have a much better idea of where to start looking.
Ok I'm going out on a limb here with Google Translate. We'll see if it works haha.
Можно ли как-нибудь вытащить код DTC из ЭБУ? Если вы сможете это сделать, я думаю, у нас будет гораздо лучшее представление о том, с чего начать поиски.
Хорошо, я иду на риск с Google Translate. Посмотрим, сработает ли это, ха-ха.
Translated for others:
Hi all! I need help! A year ago, I ran into the problem of a short fuel correction 125 (row 1 and 2).
I changed everything that is possible, but unfortunately does not help! Some kind of fuel problem.
I changed the entire fuel system (injectors, injection pump, injection pump), cleaned the line itself.
Checked the flywheel, crankshaft and camshaft gauge.
In general, if anyone has encountered a similar problem, tell me what to do!
See less See more
Reactions: 1
I'm not sure where to go from there. Might see if @Avedis53 can weigh in on the issue.
I have no idea what a "short fuel correction 125" is. If there aren't any DTCs, where did this come from?
Year and engine size please.
short fuel correction 125% - AFR 20
I have a problem with the fuel mixture ... there is no air leakage.
Guessing he means is short term fuel trims are at 125%
Did you change the fuel pressure sensor ?
You are actually getting more air than expected or less fuel pressure than expected.
What year and engine? Do you have aftermarket intakes?
Yes, that's right, I'm talking about them! I've been trying to figure out the problem for about a year now. I wondered if anyone had a similar problem?
I changed the fuel pressure sensor!
the intake ducts were basic and just put filters of zero resistance. I have tried different configurations. VR30DDTT 2020
1 - 9 of 9 Posts
