1 - 20 of 48 Posts
And if you look at the Climate setting in InTouch or the top display it will tell you which temperature setting you are on.
And this has to do with sales numbers? :confused::confused::confused:
Page 3-10 of InTouch Manual. Each time <(Heated seat button> is pushed, the seat heating mode will change in the following order:
AUTO-> High-> Medium-> Low-> OFF
Or, you can go into the InTouch screen, and go to the climate settings.
I'm surprised. I hope this doesn't sound too mean but, was it that confusing to understand how the heated seat controls worked?
:eek::eek:
You mean I fell for it?
:eek::eek:
Reactions: SimpsonTide985
or to take a minute to look in the manual before posting a question...
Discussion Starter · #16 ·
I just wanted to get some feedback on where/how the confusion occurred.
OK. I guess I have to explain why I had the question. :) No issues.
I started using the heated seats 2 weeks ago and had it turn on. Never touch the button since. I didnt feel the heat like I did on the QX60 where there is a dial next to the cup holder to change the intensity.
I guess If i would have decided to turn it off, I would realize by pressing it twice, it changes the intensity.
Sorry for asking....
Oh, so you were under the impression that the button was simply just an On/Off without a way of changing its intensity? Also since it had been such a long time since you realized that you had the heated seats on and since there was no dial like in the QX60, in your mind, that was the only available setting.
Ok, I get it now. Fair enough. :)
Maybe it's still a bit of a stretch but at least I understand where the confusion occurred! :p ;)
Regardless of what's in the manual, passengers don't read it. My wife tried it and said nothing happens when you push the button. She's absolutely right, because there is no indicator at the button you are pushing. BMW manages this correctly with LEDs. The button toggling through four positions is not intuitive because there's no feedback.
Reactions: tt_45 and afrosheen
You don't feel that the information displaying in the screen as Auto-High-Med-Low as feedback?
1 - 20 of 48 Posts
