Recently I had a P0315 pop up on my dash I was wondering if anyone had experience with this fault. I have no idea where to start. Anyone have any advise
Has anyone answered on exactly where this sensor is?I cleared it and came back... by the way this is a 3.0t and where would the crankshaft position sensor be located ?
The crankshaft position sensor is located on passenger side/which is also called bank 1. If you look behind valve covers near fire wall ypull see camshaft sensors. If you look way down yonder lol under the exhaust manifold the crankshaft sensor is way down there. Hard to get to but is possiable i did it myself but tight squeeze.Has anyone answered on exactly where this sensor is?
The person who posted that was a one-post wonder a couple years ago. You probably won't get a response.The crankshaft position sensor is located on passenger side/which is also called bank 1. If you look behind valve covers near fire wall ypull see camshaft sensors. If you look way down yonder lol under the exhaust manifold the crankshaft sensor is way down there. Hard to get to but is possiable i did it myself but tight squeeze.
Thanks for posting some good info. When you replaced your sensors, did you go from the top of the engine or from underneath?The crankshaft position sensor is located on passenger side/which is also called bank 1. If you look behind valve covers near fire wall ypull see camshaft sensors. If you look way down yonder lol under the exhaust manifold the crankshaft sensor is way down there. Hard to get to but is possiable i did it myself but tight squeeze.
Ok kool figured i would atleast say what i know for the next manThe person who posted that was a one-post wonder a couple years ago. You probably won't get a response.
