The turbos are both oil and water cooled. You do not want to turn your engine off when the turbines are still spinning quickly after a pull, it shouldn't take more than a minute after a decent WOT pull for the turbines to fully slow down though. You don't want to do a massive pull, and immediately turn off into a parking lot and shut off within 10 seconds. However the time it take to slowly drive up your neighborhood road, into drive way, into garage etc... Should be plenty of time for the turbines to slow down and everything to cool down to a reasonable temp. Idling beyond that wont really do much. Mainly you just don't want to stop oil circulation while the turbines are still spinning in excess.
In non water cooled turbos a turbo timer is used to keep circulation going for about 30second after engine shut off. This isn't needed in water cooled applications as it doesn't get as hot and cools down quicker off boost.
Really it comes down to conditions leading up to shutting down, if you just beat on her for 30mins on a track that's a different story than a 20min commute home where you had a little fun on the way. the former could use some good cooldown laps, the later the roads leading to your house should be plenty of time.
