I'll be happy to weigh in, but I'm not sure what I'm weighing in on. Explain it to me like I'm not used to sports/luxury car terminology...Whats the word, does it do it or not?
Infiniti literature is inconsistent. My guess is NO. Or maybe it will when the gas engine is running?
Hybrid guys chime in?
Mike S.
He is asking if the transmission matches the revs when downshifting into a lower gear ....via the paddles on the steering wheel or the gear lever.I'll be happy to weigh in, but I'm not sure what I'm weighing in on. Explain it to me like I'm not used to sports/luxury car terminology...
Since I've never experienced it, I'm not sure I'd know. I've driven a MT for years and "match my own revs" so I've never had a car that did this. Granted, I don't own a Q50 yet and I'll be test driving a hybrid Saturday. I've already test driven Premium and sport gassers.He is asking if the transmission matches the revs when downshifting into a lower gear ....via the paddles on the steering wheel or the gear lever.
What he saidTell me what to do and I'll let you know. I have a hybrid sport.
I am pretty sure it does it, I haven't messed with it enough to make 100% sure. My Z had rev matching and it was awesome.Whats the word, does it do it or not?
Mike S.
Yep. In the world of racing using a manual, it's called "heal and toe" which you're probably more familiar with.I did some research and I think I know what to look for. A blip increase to the rpm as soon as I downshift
Oh then yes, it absolutely rev matches. Video coming soon2010 Infiniti G37xS Sedan - downshifting using paddle shifters, great engine sound - YouTube
This is dowshift rev matching, the ECU blips the throttle as it downshifts so the rpms smooth hit the correct rpm that a lower gear at the same speed would be.
In a traditional auto, dropping a gear or two produces the effect of dropping an anchor as the lower engine speed is forced up BY the downshift, thus you loose speed as it happens.
If you downshifted when the gas engine was off, the gas engine would simply turn back on at the appropriate rpm.So then let me further confuse you. If your in manual mode say 7th gear...and let off the gas. Will the engine shut off? If so, and you drop a few gears via the paddles, what happens?
That would be a good test. I think when the hybrid is coasting it regenerates battery. I only say this cause when watching the fuel flow screen, the battery shows that the car is recharging it when coasting - I have not noticed a coasting "drag".A cool test would be for a hybrid and non-hybrid to both travel at the same speed next to each other. Say 70 mph. If both let off the gas at the same time, the hybrid should roll easier and pull ahead as the non-hybrid slows quicker.
Thanks for posting this.2010 Infiniti G37xS Sedan - downshifting using paddle shifters, great engine sound - YouTube
The song playing in the car is "It Goes Like This" by Thomas RhettHere you go. I didn't give it any extra gas when I downshifted but you can see what it does.
Hybrid Sport rev matching - YouTube
