I just found a Brand new left and right, in the boxes, full turbo assemblies with electronic wastegates and manifolds for my q50 on eBay. I went ahead and grabbed them before they were gone. They were not from the same seller. I got the right from one seller and the left from another seller both of them shipping and handling were around $650 each. I could not pass that up whereas a brand new one is around $1500. Here’s my question the right side states it is for a 2016-2020 q50/q60 300hp 3.0t. The other seller states his is for 2016-2022. Not sure what that last two years of difference is from 2020-2022 but the right side one says it is the updated version with the temp sensor omitted. And that it will need a “relearn” and apparently there is a know process for that. Now, I am not sure if the other side I bought has this temp sensor omit (I have reached out to him to ask still waiting on his reply) My question is as follows…Is there an issue if one turbo doesn’t have the omit and the other side turbo does have the temp sensor omit?
I did get this response from one seller
“Hello, good question. After the ECM is reprogrammed to omit the sensors it doesn’t matter if one side still has one or not. We replace just one side turbo often leaving a sensor turbo on the other side and the ECM will no longer look at the sensor data. We normally just unplug the other side and cut the wire clean off the sensor. You will have no issues either way. Thanks for your purchase!”
THIS SOUND RIGHT? Just want to make sure.
