21 - 25 of 25 Posts
Anyone with a Front Sonar should be running a grille. It's not something you want to have to replace out of pocket. Google the price on that bad boy.
The four sonar sensors are in the front bumper cover and upper grille. I believe you are referring to the radar sensor that is on the passenger side of the lower grille. Those run about $1,200.
If someone knows does coolant temp above 150 matter or is it only cact that effects timing
I believe coolant above 150 will start to pull timing. I had that until my Frozen Boost 101 got installed
Aren't you guys more worried about the charge air temp than the coolant temp? I mean I would.
And just so we are on the same page, we're not talking about engine coolant temp here but the charge air coolant temp.
21 - 25 of 25 Posts
