where is this fan relay exactly?Alot of people say to also pull the fan relay which can cause a low battery.
I have lithium battery with a special charger, but dont want to hassle with it. I will pull the fan relay though if someone points me to it.Not going to lie - first time flashing is a nail biting experience. If you have a trickle charger handy - use it as your battery will take a serious hit when it starts the flash and those fans start spinning.
hmm...if it is not too much trouble, which fuse/fuses would that be?In your Fuse, Fusible Link and Relay Box, you'll find cooling fan relay 1. However, the wiring diagram shows for the high output VR30, a second cooling fan relay and control module. Evidently, the HO engine controls the fans individually. The LO engine only has one relay and one control module for both fan motors. I can't find where the second relay is located.
Perhaps pull the fuses for the fan motors instead?
They are fuse "T" (50A) and "U" (50A) in fusible link holder #2 by the battery. This is all I could find:hmm...if it is not too much trouble, which fuse/fuses would that be?
ecutek ots 91.Is that with an Ecutek tune or JB4?
Would like to see how that compares with a Dragy. I would have expected quicker being AWD and an Ecutek tune.ecutek ots 91.
ams intakes, gthaus exgaust, hx and coolant exp tank.
i sent the logs to AMS and asked them to give it a once over.
I should have run it the opposite direction as well, but I wanted to get the hell out of Mexico asap.
no dragy...email address, profile, etc.Would like to see how that compares with a Dragy. I would have expected quicker being AWD and an Ecutek tune.
probably the same thing that happens to the Canadians who venture into Mexico for similar runs 😉Hey Jodedor , answer a question for me, I hear that many of you that live close to the Mexican border go over to do street racing. What happens if the Mexican Police stop's anyone, do you make it back to the states.
