So I had my first in-touch bug tonight. Map data wouldn't load (SD card error message).
I tried a bunch if things to see if I could bring it back. Nothing worked except turning the car off/on.
One of the things I tried was calling Infiniti Connection to see if they could download a destination to see of it would force the map to pop up.
Interestingly, they were unable to find the location of my car. They tried a few manual 'sends' of the info but that didn't work either. No nav map - IC unable to locate the vehicle.
This is important since one of the benefits if the IC is the emergency notification if there is an accident or air bags deployed, etc. So if you are driving around without your map showing on the screen and have an accident, you won't be able to rely on IC being able to locate your car.
My suggestion, if your map isn't showing up, pull over and restart your car so you have the emergency services available.
I don't have the update yet so I'm sure that will help but I thought people should know about this.
