good afternoon to all my Infiniti Q50 rwd has just failed and I connected the computer and I vote the code p0720 I want to know where that sensor is because my car is rwd
I'd like to know if the OP has a 2014-2015 non-hybrid Q50 before pointing him at the TCM/control valve body, since the ITB only applies to those years. It's not a given that replacing the valve body is the correct procedure in every case for a P0720, however replacing the valve body is a lot simpler than cracking open the transmission to access the output speed sensor. Either replacement can be a challenge if the owner decides to do the repair work themselves.Read this thread for all you need to know on that code and what to do.
2014-15 Q50 3.7 Valve Body Replacement / P0720 Code
**Please note, I've attached this post, in PDF format to this post, as the steps are numbered on the attached PDF, but not on the post. Here is a Quick write up on replacing the Valve body on the 2014-2016 Q50 with the VQ37VHR Motor & RE7R01A Transmission. The P0720 is a TCM short code, and...www.infinitiq50.org
