1 - 1 of 1 Posts
· Banned
Located in
Infiniti Q50 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Infiniti Q50 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 Untitled Document Type Aluminum Wheel adapter 8 mm Application All Subaru 5 x 100, 5 x 114.3 All Honda 5 x 100, 5 x 114.3 All Mazda 5 x 100, 5 x 114.3 All Mitsubishi 5 x 100, 5 x 114.3 All*Toyota*5 x 100, 5 x 114.3 All other Japanese Cars with 4 Holes / 5 Holes All BMW 5 x 120 All Mercedes Benz 5 x 112 All* Audi / Volkswagen 5 x 100, 5 x 112 All Ford, Peugeot, Citroen 4 x 108 All SAAB / Volvo 5 x 110, 5 x 108 * Description 100% Made by Cast Aluminum Price For 2pcs (1 Pair) Incredibly strong and very lightweight Specification Bolt Pattern can fit on these range: 5 x 108 / 5 x 112 / 5 x 100 / 5 x 114.3*/ 5 x 120 / 4 x 100 / 4 x 108 / 4 x 114.3 Center Bore:*77.5 mm (3") Spacer Thickness :*8 mm* ( 0.32 inch ) Package Included Wheel Spacer x 2 pcs Item Specifcations Placement on Vehicle : Array Surface Finish : Sand Polishing Thickness : 8mm/0.315inch Payment Method We accept verified PayPal payment only. Return Policy If any item is defected upon receipt, please contact us for returning instruction.* Return of goods is accepted within 7 days after item is received from buyer. * Returned item must be in its original condition. Buyer is responsible for returning shipping costs. * After receiving the returned item, a replacement will be dispatched depends on stock availability. * The warranty does not cover driver incompatibility, normal wear, unauthorized firmware upgrade, non-rechargeable batteries, consumable, and damage due to accidents, physical force, water, fire, power surge, act of God, or other mis-use. Feedback Ratings It is important for us!! Your feedback makes our feedback better. Please leave us a positive feedback and Good Ratings. We will return same feedback to you, too. * Your recognition will make us more confident in developing our business and serving you better. * It is our goal to ensure you are a happy buyer and feel pleasant shopping with us.* If you have any unsatisfactory with our service, please e-mail us before leaving any 1 or 2 ratings, negative feedback or open any dispute. Nothing is more important than your concerns and frustrations; we will do our endeavor to solve your issues. Please give us the opportunity to solve your problem. Contact Us Providing good customer service is our first priority, if you have any question, please contact us and our staff will assist you with best effort. We normally get back to you within 24-48 business hours. * For the functional products in our shop, such as chargers, data cables, we have tried our best to ensure they function as the same as description, however the actual color and shape may looks slightly different from pictures because of the technical improvement and manufacturing variance. * Please be advised before you buy it now. Policy 5 * * Autofittings Racing Fittings, Hoses, Filters, Clamps, Tool Sales & Promo Fittings Hoses Fastener Brake Fittings Search Shop Category ?*Store Home *? *Fuel Hose *?**Nylon Braided Hose *?**PTFE / Teflon Braided Hose *?**Stainless Steel Braided Hose *?**Aluminum Hard Hose *? *Swivel Reusable Hose End *?**AN4 *?**AN6 *?**AN8 *?**AN10 *?**AN12 *?**AN3 *? *AN / NPT Adaptors *?**AN to AN *?**AN to NPT *?**AN to M *?**NPT to NPT *?**NPT to Barb *?**AN to Barbed *?**M to Barb *?**Other *? *Brake Fittings *? *Banjo Fitting *? *Bulkheads & Nuts *? *Flare Plugs and Caps *? *Flare Union *? *Fuel and Gear Filter *? *Fuel Delivery Adaptor *?**Toyota *?**Subaru *?**Honda *?**Mazda *?**Mitsubishi *?**Fuel Delivery Adaptor Kit *? *Hose Finisher *? *Hose Separator / Clamps *? *Metric *? *Port Plug *? *Push-On Hose End *? *Quick Release *? *Tee Pieces *? *Tools & Wrench *? *Weld Bung *? *Y Block *? *Toppier *?**Automotive **?**Adjusting Screw Nuts /Grommets **?**Automotive Tools **?**Blind Rivets **?**Car LED Light **?**Car Wiper Blade **?**Door Lock Cilps **?**Extruded U Nuts /Foldover Nuts **?**Hole Plug **?**Hood Stand **?**Plastic Fastener / Rivet **?**Plastic Retainer **?**Push Mount Wire Ties /Zip Ties **?**PVC Plastic Washer/O Ring Seal **?**Routing Cilps / Seperator **?**Spring Clamps **?**Others **?**Steel Retainer *?**Electronics **?**Cable Tie and Mounting **?**Coaxial Cables **?**Nylon Cable Gland **?**Nylon Screws, Washer and Nuts **?**Spacer Support **?**Wire Connector *?**Home **?**Clamps *?**Industrial **?**Stainless Steel Washer **?**Aluminum Alloy Washer *? *Bosch 044 Pump & Parts *? *Fire Sleeve *? *Hose Joiner / Connector *?**Aluminum *?**Brass *?**Plastic / Nylon *? *Hood Damper *?**Cherokee *?**Citroen *?**Ferrari *?**Ford *?**Honda *?**Infiniti *?**Isuzu *?**Lexus *?**Mazda *?**Mitsubishi *?**Nissan *?**Opel *?**Subaru *?**Suzuki *?**Toyota *?**Volkswagen *? *Silicone Rescue Tape *? *Vehicle Blackbox DVR *? *Oil Cooler / Oil Cooler Kit *? *Audio *? *Hobby-Toys Infiniti Q50 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 Untitled Document Type Aluminum Wheel adapter 8 mm Application All Subaru 5 x 100, 5 x 114.3 All Honda 5 x 100, 5 x 114.3 All Mazda 5 x 100, 5 x 114.3 All Mitsubishi 5 x 100, 5 x 114.3 All*Toyota*5 x 100, 5 x 114.3 All other Japanese Cars with 4 Holes / 5 Holes All BMW 5 x 120 All Mercedes Benz 5 x 112 All* Audi / Volkswagen 5 x 100, 5 x 112 All Ford, Peugeot, Citroen 4 x 108 All SAAB / Volvo 5 x 110, 5 x 108 * Description 100% Made by Cast Aluminum Price For 2pcs (1 Pair) Incredibly strong and very lightweight Specification Bolt Pattern can fit on these range: 5 x 108 / 5 x 112 / 5 x 100 / 5 x 114.3*/ 5 x 120 / 4 x 100 / 4 x 108 / 4 x 114.3 Center Bore:*77.5 mm (3") Spacer Thickness :*8 mm* ( 0.32 inch ) Package Included Wheel Spacer x 2 pcs Item Specifcations Placement on Vehicle : Array Surface Finish : Sand Polishing Thickness : 8mm/0.315inch Payment Method Return Policy Feedback Ratings Contact Us We accept verified PayPal payment only. If any item is defected upon receipt, please contact us for returning instruction.* Return of goods is accepted within 7 days after item is received from buyer. * Returned item must be in its original condition. Buyer is responsible for returning shipping costs. * After receiving the returned item, a replacement will be dispatched depends on stock availability. * The warranty does not cover driver incompatibility, normal wear, unauthorized firmware upgrade, non-rechargeable batteries, consumable, and damage due to accidents, physical force, water, fire, power surge, act of God, or other mis-use. It is important for us!! Your feedback makes our feedback better. Please leave us a positive feedback and Good Ratings. We will return same feedback to you, too. * Your recognition will make us more confident in developing our business and serving you better. * It is our goal to ensure you are a happy buyer and feel pleasant shopping with us.* If you have any unsatisfactory with our service, please e-mail us before leaving any 1 or 2 ratings, negative feedback or open any dispute. Nothing is more important than your concerns and frustrations; we will do our endeavor to solve your issues. Please give us the opportunity to solve your problem. Providing good customer service is our first priority, if you have any question, please contact us and our staff will assist you with best effort. We normally get back to you within 24-48 business hours. * For the functional products in our shop, such as chargers, data cables, we have tried our best to ensure they function as the same as description, however the actual color and shape may looks slightly different from pictures because of the technical improvement and manufacturing variance. * Please be advised before you buy it now. * * Welcome to Autofittings Ebay Store. Enjoy Shopping! Powered by SoldEazy Desktop Mobile Buy Watch
1 - 1 of 1 Posts
