So I have owned the car for approximately five or so months. I'm right at the precipice of going and getting its oil change and brakes redone possibly, filters, etc. I'm sure the private dealer I purchased it from only did what they had to for selling condition. I had my mechanic look it over. no issues seen. After that. Since then, I've put around 4,000 miles on her. which puts me at the 40K Mark now. The car runs beautifully for the most part. Aside a little bit of a jumpy cvt between 2-3 gear shift (I'd call it normal).
Only issues I've had are some brake clicking due to some hardware my guess is. And an ever so slight burn smell. I don't ever smell it through the cabin vents themselves. Although every time I get out of my vehicle, and I have exercised the engine. Right as you step out of the vehicle near the mirror, and in the windshield wiper bay. I stick my sniffer in the back corner of hood. I smell a, i would almost say... like oil ? but electrical at the same time, maybe a plastic? it's very indistinct in the way that it smells. In no way is it overwhelming or really even terribly noticeable unless the wind is blowing the right . Or you're actively looking to smell for it. Be it that. There is still a slight burning smell. It's not sweet and syrupy although I have caught a sweet syrupy vapor smell once. when opening the hood. (Ive topped off my antifreeze which has remained level since topped off ) months ago.
But it just smells like hot Steel. I know that it could be a lot of different things. Things that Could be leaking, rubbing. Not aligned. little bits of oil/ coolant on to hot metal pieces. Electrical.. but is there anyone who can say that they have had a problem similar? Or common ailments that the car is known for? Year and age considered? I can't say that I've ever smelled it inside the actual wheel well. But the smell could be rising up it and getting trapped? I dont smell it on my passenger side Hood corner really at all. Every time I open the hood to look for leaks I can't seem to find anything leaking (topside). Could it be a seal that commonly fails or a belt that's rubbing? anyone's two cents is appreciated!!
Best,
Rw
Best,
Rw
