1 - 20 of 27 Posts
aight fellas i made a booboo when changing the oil on my 2015 q50 and added too much oil because i was going by looking at the level on the dipstick, obviously i now know that the vehicle has to be flat to record an accurate reading and i had it up on oil change ramps. so, does anybody know the inside diameter of the oil dipstick hole? i need to draw about 1/2 a quart out.
regards,
big Ed
Don't have the measurements on hand but I'd just crack the oil drain plug and let some oil out, its a PITA but it would be easier than trying to pull it out via the dipstick I'd wager. But yeah once you hit about 1/2 or 3/4 to the full mark on the dipstick while on ramps stop and get a clean read once she's on level ground.
It's easy easy to add more if you a touch under.
Maybe remove the oil filter and dump that out. Might get you close?
^ Oil filter isn't a bad option either, would be a bit messier than the drain plug but if you don't easy access to the plug not a bad alternative.
Well fellas to help any other guy....I tried the 1/4” diameter hose down the oil dipstick hole and it’s a no go. Got to a point that it wouldn’t go any further. So, I guess I’ll get the impact driver out with a 10mm socket on and take the plastic shroud off and either loosen the drain plug or loosen the filter. I over filled by approximately 3/4 of a quart. So, I need to drain out a quart then check when the car is off the ramps. Does anybody know how much oil the filter holds? I didn’t measure when I changed the oil.
Big Ed
Maybe 100-200mL (1/5 a quart?) Depends on the make/model of your oil filter you use however, more will probably drain out than what the filter capacity actually is as well. Honestly though you are probably better off just pulling the drain plug for a second. You only need to get your car up on ramps and not remove the entire under shroud.
St. Louis, MO
Big Ed
Oil filter won't be that much...maybe 1/4 quart at best...I wouldn't bother with it and the mess it will make. Personally I wouldn't sweat that amount of overfill....well within margin of error. In fact the 3.0t came out with an updated dipstick a couple of years ago to add 1/2 quart of oil to the fill capacity.
Aye he's driving a 2015 so 3.7L motor , the capacity increase was only for the VR30 motors not the last generation.
St. Louis, MO
Yep...just illustrating that there is cushion in oil capacity for most engines.
Fair, I'd personally consider 1/4 quart to be around that range for a VQ37 though.
You should drain the oil. It will hopefully come out with the oil. If not you will have to remove the oil pan. I’m not sure if it would damage the engine itself but if it gets cut up it could plug up oil passages.
Discussion Starter · #15 ·
i've decided to just crank her up long enough to roll up on ramps and pull the freaking 20ish 10mm bolts to access the drain plug and remove the plug for a few seconds then plug her back up. i wonder will the crush washer still be ok to use? i put a new one on when i changed the oil a couple days ago.
thanks for all the thoughts on this guys,
Big Ed
I'd replace the crush washer. Cheap insurance!
St. Louis, MO
Big Ed
I have done a hundred or more oil changes and have never changed a crush washer. Don't think I have ever had a drain plug leak. You should be fine just playing out this oil change cycle after draining the desired amount.
But a crush washer costs $0.20. Not disputing your experience, but they are cheap and specified to be changed as part of the job.
Reactions: jcb and BigHeadClan
I've re-used crush washer a few times when I've forgot to stock up to no ill effects but yeah doesn't make sense to actually penny pinch and re-use them if you have a fresh one.
St. Louis, MO
Don't get me wrong, I am not recommending to not use new crush washers. I have been to lazy to order/ buy them for my oil changes and have gotten away with it. For his operation it is going to be much easier to loosen the bolt until some oil starts coming out than to take the bolt all the way out to replace the washer.. He will likely be fine just re-tightening it and getting a more controlled flow to get just that limited amount of oil out.
Reactions: Big Ed
1 - 20 of 27 Posts
