1 - 12 of 12 Posts
2016 Infiniti Q50 Premium 3.0t AWD - Black Obsidian
In the process of swapping out all the aluminum CF trim inside for the Maple Wood grain trim. Have everything I need besides the trim pieces that are on the doors.
Does anyone have a part number and know whether or not swapping these out is a easy task?
If the answer is already out there my apologies, I haven’t found anything
Discussion Starter #2
Simple swap out, just waiting for the door panels. Gonna replace the whole panel instead of just the aluminum CF trim piece, much easier.
Only issue will be removing these door handle inserts I have to get to that screw to remove the door’s panel. Shouldnt be much work tho. Ignore the “wood” on the door panel currently, just a dash kit .. that ended up not fitting completely anyway.
Nice job. So sometime between 11 days ago to 38 minutes ago, you install an '18+ shift knob and boot! :) Nice. Do you have the part numbers for those? Last time I checked ebay, they only had the Q60 boot. I wasn't sure if it would fit the Q50.
How did you get that Infiniti etching on the inside of your interior door handles? Looks nice.
Discussion Starter #5
Slow and steady wins the race right? Lol. Got both parts on ebay.
Boot - Infiniti NISSAN OEM 17-18 Q60 Center Console-Shift Boot 969365CB0A
Shift Knob - Genuine OEM Infiniti Shifter Knob Handle Q50 Q60 QX60 QX80 Part#34910-9NF0B
2018+ Q50 or 2017+ Q60 parts will both fit and you will see different but similar parts numbers between the two.
The Infiniti in the door handles is just a sticker, see link.
(Amazon.com: Eppar New Decorative Inside Handle Bowls 4PCS for Infiniti Q50 2013-2016 (Black): Automotive)
Thanks dude! I think I will do both the shifter and the stickers! Thanks.
If you're referring to the inside handle bowls, they won't fit your car.
Discussion Starter #8
Evidently enough for the manufacturer to state they won't fit a 2018+.
I have '17. Stickers won't fit? Oh, I see the listing is for '13 - '16. Was there a '13 Q50? Did the interior handles change in '17? $40 is a bit high for stickers. But I think I will get them if they fit.
Hmm... some more options on ebay. They have CF inserts (no logo) as well as some stainless steel ones (with logo).
Most listings say '14 - '19 so I suspect they will work for all Q50s.
94269
Discussion Starter #11
For what it’s worth, I got mine off Wish shipped from China and some of the lettering is starting to move around. If you look close at my passenger door pic you can see the last “i” in Infiniti is missing. Not sure if that’s product based or maybe from sun exposure but I figured Amazon seller would prob be better.
I agree I think they would fit any Q50.
I learned what a handle bowl is today!
1 - 12 of 12 Posts
