Hey Folks - hope everyone is well, been having a hell of a time with my suspension post upgrade and wanted to see if anyone has ideas. I've searched this forum for days around "clunking" and "clicking" noises, and while they all have been helpful, the shop wasn't able to resolve after reviewing the posts/suggestions.
Parts that were installed:
Current Issues:
After everything that has been done, the clunking and clicking noise remains. I'm hoping SPL support will be able to help them but it's hard to be that optimistic after 3 days of a shop triple checking everything.
Does anyone have any ideas/thoughts of what else could be causing this? Really banging my head against the wall on this one, espesically after all the money that was spent for this upgrade.
Thanks in advance!
- RS-R AWD I-Active Coilovers
- SPL Front Upper Camber Arms, Rear Camber Arms, Rear Toe Arms, Rear Traction Arms, Adjustable Front Tie Rods, Lockout kit
Current Issues:
- Clunk Noise: The driver’s front coilover doesn’t seem to be working compared to the others. When the drivers front tire hits a hole the C/O feels as if it’s bottoming out with a loud clunk/hollow noise.
- It also feels like there’s another clunking noise from the front center sway bar/skid plate area. You'll hear this noise when both tires go over something like a speed bump.
- Clicking: while turning the wheel full to the right or left at slow speeds there will be a metal clicking noise, almost feels like something is breaking/twisting.
- The shop has determined the CV joint is not damaged
- They replaced the front end links with SPL parts and reinstalled the front sway bar
- Triple checked the coil-over was loaded properly prior to putting the car down off the rack. Confirmed there is no spring-bind taking place.
- All SPL parts seem to check out, nothing broken, etc
- The shop is calling SPL later today to work with their support team in hopes they missed something
Thanks in advance!
