1 - 11 of 11 Posts
2019 Infiniti q50 3.0t Luxe
Goodmorning/evening, Sirs/Ma’am.
this is my first time to do a data log. And i just need some inputs. This is my first pull from 3rd gear. 50mph to 85. Idk if i did it right. My gas is 91 octane and the weather is 90 degrees.
thank you.
edit: im on map 1 btw.
Rectangle Slope Font Line Parallel
Thank kind sir,
How do i know if i could go up to map 2. or map6?
Pay special attention to ign1. If it stays below 5 or if you are large drops in timing except during a shift, that would be a sign that the car is knocking.
Appreciate it Sir,
And for future reference lets say that i the ign1 dropped to 5, is there a way to fix that or would that just mean im overworking it and i need to lower it down?
Appreciate it Sir,
Either more octane, better cooling, or less boost.
how do you read the HP on the chart?
You can't. If I remember correctly, there isn't even a MAF airflow parameter to log that you could guesstimate from it.
1 - 11 of 11 Posts
